Oil trap installed pic?
Old Mar 31, 2008 | 02:52 AM
blackxfire's Avatar
Default Oil trap installed pic?
Does anyone have a pic of the oil trap set up installed on their car? I have a non-AMG. Where is the pcv valve. I tried to find it quickly but I didn't see anything that looked familiar on the engine. Thanks.
Old Mar 31, 2008 | 06:09 AM
robby363's Avatar
Default Re: Oil trap installed pic?
Stan, The attached thumbnails are from the service manual hope it helps. I also found this that might help. It's not the same motor but it should give you rough idea.http://www.mbworld.org/forums/showth...ight=oil+catch
Old Apr 1, 2008 | 02:45 AM
blackxfire's Avatar
Thanks Robby,
I couldn't view the MB thread because it asked my for a login.
Stan
Old Apr 1, 2008 | 07:48 AM
So does this mean there is actually no actual PCV Valve ??
Old Apr 1, 2008 | 07:58 AM
robby363's Avatar
I think #2 in the pic is suppose to be the PCV.
Old Apr 1, 2008 | 08:28 AM
OK Thanks for the info
Old Apr 1, 2008 | 11:09 AM
tbrenan's Avatar
This reminds me of a thread on the Chrysler Intrepid page, their solution to sucking engine vapours into the intake track, was to install a small bottle in the line, I forget the make but it has an in & out line on the top almost like the ones on a compressor, there are plenty of pictures of the amount of oil collected and kept from dirtying up the intake.
We used to have an 93 Topaz V6 that sucked oil into the intake, it required reqular cleaning, never could fix it up, but the car ran better when cleaned
Perhaps an "oil trap" could help our cars
Old Apr 1, 2008 | 02:26 PM
blackxfire's Avatar
I still didn't see a PCV valve in those diagrams. If there isn't one then no wonder we are getting oil into the chamber. Where are the usual motorheads on this forum that have all the answers? They haven't chimed in on this.
Old Apr 1, 2008 | 03:36 PM
robby363's Avatar
This one might have a better answer. I guess it doesn't have a regular PCV valve like most cars. The valve looks like this but they hacked it up for the catch can install.
Old Apr 7, 2008 | 08:35 PM
zacknolden's Avatar
These pictures expalain 'em better! Thanks dude! I just having hard time in figuring the pcv on the first thread.
__________________________________________________ __________
My new bmw 540i alternator | My new bmw 540i catalytic converter
Old May 11, 2008 | 06:55 AM
huudoo's Avatar
thanks .................!
b ....................listing
Old Sep 4, 2009 | 09:22 PM
As explained to me at Woodward, our cars do not have a pcv valve, but a pcv system. It works the same way, but our engines/ecm must be able to compensate for the vacuum leak without the PCV valve.
Even with a PCV valve, you will suck oil, gas, and moisture vapors thru the system, that is what it is made for. The valve won't stop that.
James
Old Aug 20, 2025 | 09:23 AM
Mmaze's Avatar
hi new the the forum is there anyone who can help me find where the in-the-bubbles ☹️🧐🥸😖 is the pcv valve located no one can find it including myself i need pictures geeeeeeeeeze!
Old Aug 20, 2025 | 10:10 AM
Please read post #12.
Old Aug 20, 2025 | 11:40 AM
There is no PCV valve as far as I know. However, if you're looking to prevent oil from flowing into the intake manifold, than it would be better to install an "Oil Catch Can". This would be an "oil trap".
I have installed one on my base roadster. I empty it every year when I change the oil. I've had a couple of ounces come out of the catch can that would have gone into my intake manifold.
Needswings.com sells the kit LINK- Oil Catch Can Kit and you get everything you need to install it.
Here's a post I did when I installed mine: LINK - Oil Catch Can Install
Old Aug 20, 2025 | 12:47 PM
dcskmail's Avatar
Here's my setup
PNA
Nov 12, 2020 04:44 PM
velociabstract
Aug 7, 2015 01:30 PM
grip grip
Other Cars Etc
Aug 1, 2015 09:18 PM
mattnelson71
Jul 28, 2015 12:52 PM
