Exterior Bulb Failure
Old May 16, 2008 | 06:35 PM
herbie53's Avatar
Default Exterior Bulb Failure
Help. re: '04 Crossfire. A warning light came on my dash. "Exterior Bulb Failure" My wife and I checked every exterior bulb we could think of. None were out. This included turn signals, reverse, parking, everything. I read what my owners manual(pg. 92) had to say. I looked in my shop manual on CD. I've spent just short of two hours looking for this bulb failure. Any ideas? Thanks!
Old May 16, 2008 | 06:41 PM
CrossfireLTD's Avatar
Cool Re: Exterior Bulb Failure
Did you check the License plate bulbs?
Old May 16, 2008 | 06:44 PM
herbie53's Avatar
Default Re: Exterior Bulb Failure
Yep, even those! I'm tellin' ya, I must be missing something!
Old May 16, 2008 | 09:21 PM
maxcichon's Avatar
Eyebrows??
Old May 16, 2008 | 10:11 PM
janobry's Avatar
my XF does the same thing... every single bulb works on mine so i just ignore the warning, though it does bother me sometimes
Old May 17, 2008 | 02:08 AM
crossfirefun's Avatar
Max has the right idea. Did you check the little marker light bulbs in the headlight housing?
Old May 17, 2008 | 03:51 AM
herbie53's Avatar
Yep, even the eyebrows. And even thogh it probably has nothing to do with it, I checked all the interior lights. So this morning, after sleeping on it, 'm starting all over.
I expect electrical gremlins from my Spitfire but this has me stumped. Oh well, everything looks better after a cup of coffee!
Old May 17, 2008 | 10:24 AM
herbie53's Avatar
SOLVED! First, thanks for all your help. After checking and re-checking all the bulbs and finding nothing my wife and I ran some errands. A guy pulls up and says that my left rear tail light is out. I pull over and we check it. It's fine and continue driving until someone else points it out. Pull over again and this time pull the bulb. Here is the fun part.....the bulb is slightly blackened and the filament in the bulb is broken in such a way that when the car is not moving the light works fine. But when underway and with the vibrations it doesn't work. Put the bulb back in...worked fine, drove it a bit...doesn't work. Now another question. It calls for a Phillips(but any brand will do) but it needs a "P21/5W. My auto parts store has several Phillips but none like this. They only have the American #, like 1157 or 2057, etc. They had no cross reference nor did my manuals. Any ideas as to the proper ones?
Old May 17, 2008 | 07:33 PM
MannyTwoTwo's Avatar
Try here https://www.crossfireforum.org/forum...ad.php?t=13577
It's the Sticky right above the "Exterior & Lighting" section.
Old Nov 1, 2008 | 09:45 AM
mcgjf's Avatar
I just experienced the exact same thing with the dash light on but no sign of a failed light. Thanks for your post, I'm off to re-check all the bulbs.
Old Dec 27, 2010 | 06:48 PM
RaulRocks2's Avatar
I have had my car for about 3 months and since last week it has been doing something similar, except mine does it only when none of the lights are on, when I switch the lights on at night the indicator turns off. It doesn't always do it. It does it for a day or two and stops for a few days. All bulbs are working even inside.
Does anyone have a clue what this might be?
I also heard some sort of noise under the center console before this happend, like a short or something. Maybe I'm just paranoid.
This is my first comment here and I searched everywhere with out luck.
Thanks in advance!
2004_
Jul 9, 2025 12:39 AM
eikon
Sep 9, 2019 10:16 PM
Nexxus
May 8, 2016 04:43 PM
toob
Sep 26, 2015 11:44 AM
maxcichon
Sep 4, 2015 12:50 PM
