Factory Head Unit Broken?
Old Jun 3, 2008 | 12:26 PM
shubi.s's Avatar
Default Factory Head Unit Broken?
I got into my car today, and tried to turn on the radio. No matter what I do and what buttons I press it remains stuck at the words "CHRYSLER". It powers on and off fine, and the eject button works also (thought it was a bad cd). I jump started it a few weeks ago, but the radio has been working fine until now..
Old Jun 3, 2008 | 12:43 PM
ichon's Avatar
Default Re: Factory Head Unit Broken?
Detatch and remove the entire unit (use the "special" key) and check the rear wire connections. One just may have come losse (It happened to me). Good luck.
P.S. If you're not still under warranty and need to purchase a new unit let me know. I have a OEM and OEM Nav unit you can have cheap. Cya Chas
Old Jun 5, 2008 | 03:30 AM
richard_r's Avatar
If you can't get it working let me know, I may be interested in the broken deck for parts for my deck, the prev. owner melted the multifunction keys with a cleaner (I think he used a spray tuner cleaner he said). I have been looking at other options as well and found the Blaupunkt is a direct wire in, no harness or cutting wires.
Old Jun 5, 2008 | 01:39 PM
shubi.s's Avatar
I guess it just needed some time to reset or something, I turned it on today and it worked like a charm.
Old Jun 5, 2008 | 01:56 PM
CALL911's Avatar
Had this happen twice. Pull out both radio fuses under the hood and put them back in. this resets the radio.
syfi
Mar 28, 2026 04:14 PM
Sterling57
Apr 11, 2016 06:11 PM
o55ie18
Oct 5, 2015 05:50 PM
crossfireE
Oct 2, 2015 01:40 AM
smokey847
Sep 15, 2015 10:47 AM
