Schrick Amg Cams
Old Jun 27, 2008 | 09:59 PM
HDDP's Avatar
Default Schrick Amg Cams
Every once in awhile I remember to post photos of the performance parts installed in my track car... Here's the Schrick cams for the AMG engine before installation. These are part # 35101681-RO & 31501681-LO Retail cost was appx. $2,300 minus a 22% racers discount. Oh yeah, forgot to mention, Schrick told me mine were the last in stock and no more were planned for mfg. I find that hard to believe...
Old Jun 27, 2008 | 10:57 PM
Maxwell's Avatar
Default Re: Schrick Amg Cams
yeah, you throw $2500 at schrick to chuck up some stock in the cnc lathe, and I'm sure they'll start cutting and grinding in no time.
how much longer for a dyno run?
Old Jul 1, 2008 | 10:38 PM
SLK32Germany's Avatar
Hello,
how is the idle compared to the OEM-Cams? At which RPM you get benefits from the Schrick-Cams and do you loose power under 3.500 RPM?
Thanks.
Bruno
Old Jul 2, 2008 | 09:41 AM
Maxwell's Avatar
I haven't the specs on these and Schricks never posted the duration or lift on thier website. they just listed the NA specs.
SC cams never have idling problems because they detune them for less valve overlapp, mostlikely they have more lift.
And since they are discontinued I'd be willing to bet, the higher lift NA cams are being used forthe SC m112's as an upgrade part, because the NA sport cams has about 1mm more lift.
hardly worth the effort for 1 or 2mm, might as well spend your money on a faster SC pulley.
Old Jul 7, 2008 | 07:03 PM
HDDP's Avatar
Well how about 22hp ?
Old Jul 7, 2008 | 07:38 PM
Maxwell's Avatar
still less work bolting on a $300 pulley that will easily make mucho power.
but I don't know ****..
Old Jul 7, 2008 | 10:55 PM
Sounds good to me
HDDP, I think if you already have pulleys,Intake,HE,Exhaust they are a good option.
Can you please give me your opinion from your own knowledge about the following points:
Idle compared to the OEM-Cams, Benefits from what RPM? Do you recommend them for everyday use?
Thanks.
Bruno
Old Jul 8, 2008 | 06:35 AM
240M3SRT's Avatar
Originally Posted by SLK32Germany
Sounds good to me
Thanks.
Bruno
+1..........
Old Jul 9, 2008 | 02:08 AM
HDDP's Avatar
Originally Posted by 240M3SRT
+1..........
I would not install the cams for street use unless you have a tuner who can access your ECU and raise the idle speed. My engine is operated by a MOTEC M600 ECU that is fully adjustable via a laptop. The OEM idle RPM is too slow and needs to be raised 150+
Old Jul 9, 2008 | 01:31 PM
240M3SRT's Avatar
Other than a raised idle im interested in knowing if hp is gained up high and if a low end tq loss is the flip side of installing the cams? And if a raised RPM is a need meaning tougher valve train is necessary.
Old Jul 9, 2008 | 07:21 PM
HDDP's Avatar
Don't have a basline dyno on the engine, so I can't give you any hard number comparisons, sorry. I will have a dyno on the full rebuild as soon as VRP "Vadim" delivers the headers that were pre-paid & promised me two weeks ago...
Old Jul 11, 2008 | 07:19 AM
240M3SRT's Avatar
That will be sweet, i almost bought a set of those headers. Refresh my memory as to what setup your running.
SRT6 transplant or turbo m112?
Old Jul 11, 2008 | 08:09 AM
ZAHANMA's Avatar
SRT6 transplant
TerryR
Dec 13, 2019 03:27 PM
4drturbo
Oct 2, 2015 12:58 PM
ala_xfire
Sep 28, 2015 05:51 PM
cjw
Sep 27, 2015 10:22 AM
Billy22Bob
Sep 26, 2015 10:16 PM
