Key stuck in the ignition
Old Jul 6, 2008 | 08:45 PM
Roadrunner's Avatar
Default Key stuck in the ignition
Please help, on my 2005 SRT-6 the key is stuck in the ignition. The car is in park, and i also tried turning the steering wheel. Thanks
Old Jul 6, 2008 | 09:02 PM
manisusmc's Avatar
Default Re: Key stuck in the ignition
try shooting a little wd-40 in there
Old Jul 14, 2008 | 10:36 AM
Altered Slate's Avatar
I had the same thing happen to me once with my SRT-6.
I put the car in park, engaged the handbrake, turned the engine off, and tried to remove the key, but it was stuck. After turning over/ shutting off the engine without freeing the key I decided to shift into reverse and shift back into park. Once the transmission shifted from reverse to park I shut off the car again and out popped the key.
I assume the transmission did not shift into park the first time, and the tumbler held onto the key as a safety mechanism.
I have not been able to reproduce this, with the auto-stick in park and the ignition tumbler still holding on to the key. The tumbler will hold onto the key if you turn the car off with the transmission engaged.
Old Jul 24, 2008 | 01:14 AM
AChinn's Avatar
hey,
That is a sign that the key cylinder in the ignition is going bad. It happened to my '04 Crossfire. I recommend you take it to the dealer to get it replaced ASAP. Mine went bad while it was still under warranty, and Chrysler paid for it and the labor. It takes them as much as 1 month to get a replacement cylinder from Germany. Good luck with it.
AChinn
fastfred
Nov 5, 2018 09:47 AM
o55ie18
Oct 5, 2015 05:50 PM
DaveMe
U.K.
Sep 29, 2015 08:09 AM
Padgett
Southeast Forum
Sep 27, 2015 09:37 AM
fastfred
Sep 24, 2015 03:05 PM
