check engine light ??
Old Jul 14, 2008 | 08:49 AM
alky68's Avatar
Default check engine light ??
i just made a cusome c/a intake the car drives great but the check engin light came on i dissconnected the battery for like 2 hours it stayed off then came back on so i did it again same thing stayed off 4 like 2days them came back on ne suggestions on what it could be this is the intake pic attached
thanks
Old Jul 14, 2008 | 09:29 AM
Stogey's Avatar
Default Re: check engin light ??
I would find someone who has a scanner and pull the codes. I have seen several posts that Autozone does this service for free.
You're not exactly pulling in cold air if the filter assy. is inside the engine compartment. Just thought I'd throw that in.
Just my Dos Centavos !
Old Jul 14, 2008 | 11:18 AM
alky68's Avatar
so is it an obd 2 scanner do u know where the plug is at on the car
Old Jul 14, 2008 | 12:08 PM
Stogey's Avatar
On the panel under the steering wheel just to the left of the column.
Old Jul 14, 2008 | 01:11 PM
alky68's Avatar
cool found it thanks alot
Old Jul 14, 2008 | 03:36 PM
Most likely it is your MAF (mass air flow) sensor that is causing you to throw the code.
NeedsWings na and srt6 CAI group buy-po171.jpg NeedsWings na and srt6 CAI group buy-po174.jpg
This occurred originally with the na Crossfire Needswings CAI
Those MAF sensors are extremely sensitive !!!
Old Jul 15, 2008 | 01:07 PM
alky68's Avatar
Default Re: check engine light ??
did you have the sam problem what did you do so it wouldnt come on any more??
Old Jul 15, 2008 | 01:14 PM
spensley's Avatar
Alky68 - I'm assuming that you have just modified the intake AFTER the plastic piece at the back of the engine - effectively replacing the stock airbox.
If that is so, then you basically have the stock setup in the way that the crank breather hose is in the same relationship as the MAF sensor as if was before your change.
Originally Needswings had the breather hose infront of the MAF which may have been causing the problem - you do not have this.
Have you disconnected the battery?
If not, then do so - your CEL will probably stay off until you hit about 50-70 miles then it may reappear - if it does not reappear then you may be home and dry.
Every time I disconnected the battery on my first Needswings intake the CEL stayed off for about 70 miles.
Now the revised Needswings intake works a charm.
Back to your intake - you're sucking in warm air!!!
Old Jul 15, 2008 | 01:22 PM
alky68's Avatar
yes i put a brather filter and i pit a rubber elbow to the actual intake and the mas and in workinf on gettinf a rubber pice to put the filter behind the grill i did disconect the battery twice and it still comes on after an day or 2 ne suggetions??
Old Jul 15, 2008 | 04:58 PM
spensley's Avatar
No ideas as to what may be wrong.
Take it to somewhere like Autozone who do free scans, they will tell you what the problem is.
Here's the Needswings CAI thread (good pics showing what I was rambling on about before)...
https://www.crossfireforum.org/forum...=23230&page=29
Hoppy
Dec 7, 2018 07:36 AM
jgreen
106
Sep 18, 2017 11:46 PM
spoiler
Sep 2, 2015 08:56 PM
axnguyen
Jul 21, 2015 11:41 AM
Mark McKay
Jul 17, 2015 01:18 PM
