Engine Cover / Air Cleaner Removal Questions
Old Jul 28, 2008 | 06:05 PM
brucero's Avatar
Default Engine Cover / Air Cleaner Removal Questions
Sorry for the newbie question. but...
The instruntions in the service manual state that to remove the engine cover, one should remove the air feeder tubes on the side of the engine cover, grab the cover at the rear and lift from the rear...
How do you remove the side air tubes? Pull out away from the cover? Lift?? Push Down??
Then, I guess there are clips at the rear of the engine cover, but what does it attach to at the front for reinstalling the cover?
Any tips and tricks would be appreciated. Especially regarding the air tubes.. I can't figure out how they are attached..
Bruce
Old Jul 28, 2008 | 06:14 PM
Default Re: Engine Cover / Air Cleaner Removal Questions
if its just the engine cover, just pull up...it pops out of the tubes in the rear, and front of engine...you will not break anything, you will see how it attaches after you pull it up and off...it is very simple design...
Old Jul 28, 2008 | 06:16 PM
if you want to remove airboxes, there is more to do...if you are just wanting to replace air filters??? Not sure where you are headed....
Old Jul 28, 2008 | 06:17 PM
Kurts's Avatar
If you're talking about the gray cover right on top then it's easy & no air tubes need to be removed. Just grab the front & pull up.......do the same for the sides & voila', you're good to go!
Put it one the same way you removed it......line it up with the clips & just give a good push.
Old Jul 28, 2008 | 08:04 PM
The engine cover lifts free from four grommets (2 in the back and 2 in the front)
The air tubes can be pulled away from the cover and flexed to be removed first or simply lift the corners of the cover one at a time and once it is free from the engine it will pull free from the tubes anyway.
If you are planning to change the 2 air filters turn the cover over to expose the bottom side.
You will see two rectangular covers with a torx screw in each corner.
You need to remove the 4 torx screws from each cover to expose filters. Then replace filters and replace the rectangular covers and screws and align the engine cover with the oil filler cap and opening in cover for it and press down firmly on all four corners of the cover.
Be sure the rear of the cover is aligned correctly over the air intake (throttle body)
Old Jul 29, 2008 | 06:47 PM
brucero's Avatar
Thank you all for your insight and experience.
I love this group.
Bruce
Old Sep 8, 2008 | 09:35 AM
joeviking61's Avatar
Yeah, I second that!! Thank you Valkryderguy!! I tried it myself a few times and couldn't figure it out, until I read your response. You Senior Guys are fantastic. I've saved some serious money already, by downloading the Maintenance guide .pdf (e-bay wants $ 190.00) and the insights/advice have been awsome.
Joe
Old Sep 8, 2008 | 06:12 PM
Joe
Your welcome,
I am always happy to help where I can.
Gary
Old Sep 14, 2008 | 08:13 PM
LVXF's Avatar
Feeling retarded here. Tried to lift the cover off but it's not budging. Can you post a pic with arrows? Don't want to bust it and then try and find a replacement. Thanks in advance.
Old Sep 14, 2008 | 09:11 PM
BrianBrave's Avatar
<--- Huge Horsepower
Old Sep 15, 2008 | 06:06 PM
LVXF's Avatar
Thanks. I'll try it this weekend.
Old Sep 16, 2008 | 10:22 AM
jlvm's Avatar
Wow, much more work that i thought . I'll better leave it to the dealer.
Old Sep 24, 2008 | 04:40 PM
LVXF's Avatar
Thanks, Brian. It was actually quite easy once I tugged hard enough. Anyone know where I can get K&N filters at a reasonable price? PepBoys has a $10 off coupon, but only for K&N filters in stock. Yep, you guessed it, the ones for a Crossfire are never in stock...
Old Sep 24, 2008 | 05:10 PM
Do a google search for K&N 33-2290
Lots of places to get these online.
Old Sep 27, 2008 | 04:10 PM
LVXF's Avatar
Thanks. Debating whether or not to install CAI system.
Ed
Old Sep 27, 2008 | 06:14 PM
BrianBrave's Avatar
Ed
The Crossfire comes stock with Dual CAI - Just remove the choke-points at the radiator support and throw in a set of K&N filters.
https://www.crossfireforum.org/forum...ad.php?t=19969
You can spend a lot more money...but it won't buy you much in terms of HP or 1/4 mile time for the Limited...besides - you can dress up that engine cover to look sweet...
https://www.crossfireforum.org/forum...ad.php?t=21260
Old Sep 27, 2008 | 09:28 PM
kldiet's Avatar
If anyone has an extra engine cover gromet (little metal insert that's found in front of the lower tray) I would sure be interested in it. Drop me a line at kldiet@***.net. Dealer lost one of mine.
Thanks,
Karl
Kodebuster
Nov 5, 2020 04:06 PM
RED DOG
May 4, 2019 08:05 AM
stlas69
Sep 3, 2015 10:28 AM
RED DOG
Jul 21, 2015 07:58 AM
jtr2901
Jul 10, 2015 06:33 PM
