Reverse, Why so much trouble???
Old Aug 11, 2008 | 09:48 PM
manderson483's Avatar
Default Reverse, Why so much trouble???
Ok so I bought my Xfire... so im cool right??? NOPE!
When I go to put the stick shift in reverse its not catching and I get the evil grinding sound. The only way it seems to work is if I hold the shifter in reverse, engage the cluch and only then it will stay in gear.
I know you gotta lift the shifter up then put it in gear but it doesnt seem to work... Am I doing it wrong or do I need to see my local dealer?
Think it would be under warrenty?
Old Aug 12, 2008 | 07:24 AM
+fireamx's Avatar
Default Re: Reverse, Why so much trouble???
If you're having trouble getting it into reverse, I do believe there is a TSB on the problem, and it should be fixed under warranty.
Good Luck
Old Aug 17, 2008 | 12:51 AM
Yeah I talked to my buddy who works for Chrysler and he said it's a common problem. He said that they need to tighten the reverse cable and align the shifter.
It is covered!
xfireohio
Jul 20, 2020 12:03 AM
Mike OD
Sep 23, 2016 07:00 AM
Billto
16
Sep 1, 2016 11:06 PM
FISHBONE
Sep 17, 2015 06:15 PM
toob
Aug 19, 2015 07:31 AM
