Cat Removal Y-Pipe?
Old Nov 16, 2008 | 01:51 PM
BLACKSRT-6's Avatar
Default Cat Removal Y-Pipe?
I know that Brian has posted the stock # for the y-pipe needed to remove the resonator. My question is does anyone know of a maker for the y-pipe needed to remove the second cats and resonator? The down pipes are wider at the inlets to the second cats so I don't think Brians Y will do the trick without adding piping to bring the down pipes closer together. Thanks
Old Nov 17, 2008 | 07:44 PM
BlueStorm's Avatar
Default Re: Cat Removal Y-Pipe?
you have to make your own catless exhaust, as this is a felony for anyone to remove the catalytic convertor. you will require O2 sims.
Old Nov 17, 2008 | 07:58 PM
Squirrel Crusher's Avatar
O2 sims???? Say What! Need a X connector for SRT-6 if going dual all the way back.
Old Nov 18, 2008 | 03:24 AM
BLACKSRT-6's Avatar
I intend to leave the down pipe as is with the O2 sensor, use a Y-pipe where I remove the lower cats and run 2-3/4 pipe straight back to the muffler.
Old Nov 19, 2008 | 02:29 AM
Skyshadow's Avatar
Why wouldn't a Cat delete work from like Random Technology? Many things are illegal for your car, doesn't mean you cant get them. Take radar scramblers for example.
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
o55ie18
Oct 5, 2015 05:50 PM
brandoni
Sep 30, 2015 07:48 PM
RacerXofFL
Sep 15, 2015 05:00 PM
