Cat Removal Y-Pipe?
I know that Brian has posted the stock # for the y-pipe needed to remove the resonator. My question is does anyone know of a maker for the y-pipe needed to remove the second cats and resonator? The down pipes are wider at the inlets to the second cats so I don't think Brians Y will do the trick without adding piping to bring the down pipes closer together. Thanks
Why wouldn't a Cat delete work from like Random Technology? Many things are illegal for your car, doesn't mean you cant get them. Take radar scramblers for example.
o55ie18
Oct 5, 2015 05:50 PM
Need a X connector for SRT-6 if going dual all the way back.
