Amp and Cap install question.
Old Nov 17, 2008 | 01:32 PM
blackxfire's Avatar
Default Amp and Cap install question.
If I am installing a Cap and an Amp. Do I use one lead from the battery and go through the Cap to the Amp or do I need 2 different sources? Another words do I have to hook up both the Amp and Cap directly to the battery or does the Amp always draw power through the Cap. Sorry never had a Cap or seperate Amp on a car stereo before.
Low wattage set-up. 400 watt amp, 300 watt sub and 1/2 Farad Cap.
Old Nov 17, 2008 | 02:29 PM
rcompart's Avatar
Default Re: Amp and Cap install question.
You want to connect the amplifier ground to the chassis adn the positive wire from that should connect to the (+) side of the cap. You also connect teh (+) ofthe cap to the (+) terminial of the battery and the (-) side to the chassis. If it's easier, You can just connect the ground from the amplifier the the (-) side of the cap. Here is a diagram that should help explain.
Old Nov 17, 2008 | 02:55 PM
blackxfire's Avatar
Thank you very much! Stan
gp1200x
Dec 6, 2015 12:59 PM
waldig
Aug 14, 2015 01:02 PM
BrenLW
Aug 5, 2015 04:53 AM
pioneer4x4
Jul 27, 2015 02:04 PM
xfireon20z
Jul 20, 2015 04:35 PM
