HID installed
Old Jan 16, 2009 | 02:02 AM
LeePie's Avatar
Default HID installed
Fitted my HID kit this week, easy fit and a great mod for our cars.
One question though, I have noticed a "hot spot" of light just in front of the car on the left side. Is this just a characteristic? I have checked the bulb if in properly (twice)
Thanks in advance.
Lee
Old Jan 16, 2009 | 05:56 AM
maxcichon's Avatar
Default Re: HID installed
When I installed mine, I used a yard (meter?) stick to compare "beam height" between the 2 sides. I would suggest pulling the car nose-in to a blank wall and looking at the pattern of light. Then slowly back away, watching for oddities.
I don't have any hotspots, just 2 dark lines-shadows of the support posts inside the capsules.
Old Jan 16, 2009 | 06:38 AM
faiz23's Avatar
the shadow you are seeing is the return wire enclosed in ceramic to protect it. cheap kits will usually have the wire at the 12 o'clock position so when the projector throws the light on the floor you will see the return wire. OEM kits and higher end hid kits like mcculloh will have the return wire at the 6 o'clock position and you do not see it on the road. some have cut the tab on the h7 bulb and rotated the bulb to where you do not see the shadow. halogen reflectors dont need to worry about this but they create tons of glare versus halogen projectors. the best thing to do is retrofit HID projectors from honda s2000 or acura tsx.
http://faqlight.carpassion.info/hid-...up-down-h7.jpg
http://www.team-integra.net/sections/articles/showArticle.asp?ArticleID=973
http://faqlight.carpassion.info/hl-hid-bulbs.htm
"There is also something known as a return-wire shadow. The small ceramic insulator that runs the length of the glass will actually cause a dark spot if the capsule is viewed head-on. A car with factory HID will have headlamps that hide this shadow; halogen headlamps will have a dead spot where this wire sits, usually at the bottom."
Old Jan 16, 2009 | 07:11 AM
maxcichon's Avatar
Geez, let me see:
Tear apart the OEM lamp assemblies to install Japanese projectors to take away a slihgtly darker line on the pavement 10 feet in front of the car.
Hmmmmmmm.......
Nope. I'll live with these cheap bustard HID's.
Old Jan 16, 2009 | 08:56 AM
faiz23's Avatar
you could always cut the h7 tab and rotate the bulb 180 and have the return wire at the 6 o'clock position cheaper than a retrofit lol.
Old Jan 16, 2009 | 09:07 AM
maxcichon's Avatar
Hmmmmmmm......
Naaaaaaaaah.
I'm just too lazy. I guess I'll have to live with it!
Thanks, though!
Old Jan 17, 2009 | 12:22 PM
07bluezx14's Avatar
compared to the difference in light output, the line I see is easily overlooked.
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
ozkancab
Sep 25, 2015 10:55 AM
AlbertFattal
Sep 24, 2015 05:03 AM
