Is there a tutorial online that shows how to manually change oil on the Crossfire?
Old Feb 15, 2009 | 06:07 PM
jamilleharley's Avatar
Default Is there a tutorial online that shows how to manually change oil on the Crossfire?
With the hardships of the economy I need a oil change. I can't afford to spend 120.00 for a oil change. I'm trying to find a how to do it yourself tutorial video. I'd appreciate any help.
Old Feb 15, 2009 | 06:10 PM
manisusmc's Avatar
Default Re: Is there a tutorial online that shows how to manually change oil on the Crossfire?
https://www.crossfireforum.org/forum...5&page=1&pp=20
here you go you'll have to buy a topsider pump or something similar, but it's worth I've changed my oil twice using this method.
https://www.crossfireforum.org/forum...=reset+service
here is a link to how to reset the counter look at post #5
Old Feb 16, 2009 | 05:32 AM
bluecoupe's Avatar
and another link:
http://www.dfwsbr.com/crossfire/faq/oil/
Old Feb 16, 2009 | 05:51 AM
TVT_DESIGN
Guest
Posts: n/a
If you have a jack and jack stands you can remove the bottom panel (4 bolts) and drain like a conventional car via the drain plug. You get a lot more oil out this way anyway. Also, don't forget to loosen the oil filter to relieve the system pressure and drop another half quart or so.
Old Feb 16, 2009 | 06:33 AM
manisusmc's Avatar
not knocking your way of changing the oil but I've gotten just a little over 8 quarts both times I've changed mine using the topsider
syfi
Jun 22, 2015 07:23 AM
WindRestrictor
Jun 16, 2015 12:18 PM
MJPowers
Jun 8, 2015 02:34 AM
Ephr8a
Jun 4, 2015 12:42 PM
WindRestrictor
Jun 1, 2015 02:31 PM
