Crank Position Sensor connector...HELP!
Old Mar 17, 2009 | 11:18 AM
MikeR's Avatar
Default Crank Position Sensor connector...HELP!
My P0335 error starting coming back again.... I have isolated it down to the @$#%$$#%# connector that plugs onto the sensor. Unfortunately it is part of a much bigger harness for the engine. So I am looking for the connector vendor/part number OR a connector with some of the wiring still connected from a wreck. This should be common across all the models.
If anyone can find this dang connector I will buy it...two would be better so I can play with one. I called about this on a wreck a few months ago and they wanted to sell the whole harness. I need help from all you scroungers out there. Thanks in advance for any help.
MikeR
Old Mar 17, 2009 | 11:52 AM
maxcichon's Avatar
Default Re: Crank Position Sensor connector.....HELP!
Sorry to hear that, buddy. Nowrecks around here and the salvage yards in Alabama are run waaayyyy different than anything I'm used to.
Sorry again!
Old Mar 17, 2009 | 12:01 PM
rcompart's Avatar
Sorry again!
I should have a harness I can cut it off for you pending another forum member getting me the harness. You just need the connector correct? I no longer have you phone number so PM me it and I'll call you when I get the harness. It should be the same between my NA and your SRT.
Old Mar 17, 2009 | 06:47 PM
LantanaTX's Avatar
If you have trouble finding one you can broaden your search beyond a wrecked Crossfire. Just about any Mercedes with the M112 V6 or M113 V8 have the same connector for the crank position sensor. these are the SOHC three valve dual plug engines. My ML320 had the same sensor and connector as well as my new V8 project engine which came from a CL500.
Old Mar 18, 2009 | 02:19 PM
MikeR's Avatar
Default Re: Crank Position Sensor connector...HELP!
here is what the CPS connector looks like....
aerobluehal1
Canada
19
Oct 13, 2018 09:47 AM
RED DOG
Oct 5, 2015 07:59 PM
Oct 1, 2015 01:42 AM
Sep 25, 2015 02:16 AM
bobbie
Sep 12, 2015 12:49 PM
