burnt light symbol still on after I changed the bulb
Old Mar 27, 2009 | 04:55 PM
windsorxfire's Avatar
Thumbs down burnt light symbol still on after I changed the bulb
burnt light symbol on dash still on after I changed the bulb. It was the brake light so I picked a pair up from Autozone and changed it....PITA checked the light after install and all was good. Parked the car for the night and in the morning started it and the burnt light symbol came back so I checked the lights all around - nothing wrong everything works the way they are supposed to.
Any ideas?
The only idea I have is I did not buy genuine mopar/benz parts.
Old Mar 27, 2009 | 04:56 PM
Default Re: burnt light symbol still on after I changed the bulb
Btw the car is the xfire roadster
Old Mar 27, 2009 | 05:48 PM
danimal's Avatar
Be sure to check the license plate lights.......they are usually the culprit.
Old Mar 27, 2009 | 07:01 PM
Moparrbust's Avatar
I haven't looked at the tails on Crossfires but on a lot of newer M-B's they have "secondary" brake lights that will light up for safety and visibly looks like nothings wrong. Then when you take out the taillight you'll see a burnt bulb.
Old Mar 28, 2009 | 08:47 AM
just checked the lights again all around is OK even the license plate lights.....what to do?
Old Mar 28, 2009 | 04:09 PM
antonio311's Avatar
disconnect the battery for 1 hour, then reconnect. then the light should disapper.
Let us know if this works.
Old Mar 29, 2009 | 07:53 AM
thanks, it worked!
Also took the tail out and tightened all bulbs!..
Thx ppl
Old Mar 29, 2009 | 06:58 PM
antonio311's Avatar
Glad it worked!
2004_
Jul 9, 2025 12:39 AM
PNA
Nov 12, 2020 04:44 PM
Hoppy
Dec 7, 2018 07:36 AM
BrenLW
Aug 5, 2015 04:53 AM
JEFASOLD
Jul 15, 2015 02:32 PM
