sprint booster
Old May 7, 2009 | 07:39 PM
svtcobra's Avatar
Banned
Default sprint booster
js put in my sprint booster but i feel no difference(((((((
Old May 7, 2009 | 08:30 PM
spensley's Avatar
Default Re: sprint booster
Then you've done something wrong.
It should be a lot quicker accelerating from a standing start.
I can't remember if it is possible to install it incorrectly or not, and whether you should disconnect the battery or not..
Try doing a throttle reset too - it's on here somewhere.
Post # 82 for throttle rest:
https://www.crossfireforum.org/forum...t=32672&page=5
Old May 7, 2009 | 08:41 PM
svtcobra's Avatar
Banned
the only thing else i did was put 285-35-19 on tha rear cld that affect it
Old May 7, 2009 | 09:37 PM
Stogey's Avatar
Try swapping the cables around !
Old May 7, 2009 | 09:56 PM
svtcobra's Avatar
Banned
should to plugin part that say sprint booster connect into tha pedal connection
Old May 8, 2009 | 07:33 AM
Stogey's Avatar
This happened to another member, the plugs do interchange !
Check to make sure you have the right plug in the right place and that you didn't bend a pin plugging it in. If all this checks out, I would say contact your vendor for a refund or replacement.
Thats just my Dos Centavos
Old May 8, 2009 | 11:13 PM
It can be plugged in two ways.
One way is wrong and you will have absolutely no throttle response
Then there is the correct way and you will absolutely feel a difference.
If you have throttle response and feel no change it's defective
Old May 9, 2009 | 02:16 AM
maxcichon's Avatar
Question Re: sprint booster
I assume you performed a Throttle Position Reset? Mine did (or didn't) do the same thing on initial install.
1. Turn the ignition key to the on (not start) position.
2. Press the gas pedal to the floor and hold for five seconds.
3. Turn the key to the "off" position (don't remove the key), then release the gas pedal.
4. Wait at least two minutes for ECU to reset.
Or
1. Get in your car, it doesn't matter if you close the door or not.
2. Turn the key to the on (not start) position.
3. Press the gas pedal to the floor with the key in the "on" position.
4. Hold the pedal to the floor for five seconds, then turn the key back
pedal.
5. Wait 2 mins. for a full alignment.
6. Drive the car as you always do.
Key on, pedal down, 5 sec, key off pedal up, wait 2
minutes. Keep the key in for the entire thing.
And this is from BenzWorld:
Reset Throttle Body
Open the door, put the key on the ignition, close the door.
Move start switch into position "2"
Press the gas pedal to the floor... past the kick down point
Hold the pedal there for 15 seconds
After 15 seconds while foot still planted, turn the key off but do not remove it
Release gas pedal... Wait at least 2 minutes while not touching anything in the car, don't open the door even.
After the 2 minutes start the car and drive off normally...
TerryR
Dec 13, 2019 03:27 PM
waldig
Jul 31, 2017 09:46 AM
unarel32
35
Oct 6, 2015 05:53 AM
waldig
Sep 2, 2015 11:02 AM
josh armstrong
Aug 18, 2015 12:36 PM
