Another lightbulb change issue
Old May 28, 2009 | 03:06 PM
Airscape's Avatar
Default Another lightbulb change issue
Long story short I did the wonderful drop the clip thing inside the light housing, now I must remove the entire light. I spent about 2 hours trying to find the screws on the bottom side of the light through the hole in front of the wheel well but cant find em up there for the life of me. Does anybody know if the sizes on the bolts are the same and where they are positioned in relation to the top? I thought I felt them all over the place but could get anything on them to turn. Thanks for any info!
Old May 28, 2009 | 03:18 PM
SNAKEWOLF's Avatar
Default Re: Another lightbulb change issue
THE BOLTS ARE ON OUTER CORNERS I HAVE REMOVED MINE
NEED TO BE CAREFUL WHEN YOU REMOVE PUT A CLOTH BETWEEN LIGHT AND BODY ON THE BOTTOM SIDE.
IF NEEDED PUT ON JACK STANDS AND REMOVE OR TURN TIRES SO YOU GET A GOOD VIEW INTO OPENING.
GOOD LUCK
OTIS
Old May 28, 2009 | 11:56 PM
Airscape's Avatar
was a pain for sure, finally just took the tire off and stuck my face up in there to see what was going on and was able to get it out. It's amazing how easy it is once you can actually see how it works =-P. Thanks for the info!
PNA
Nov 12, 2020 04:44 PM
waldig
Sep 2, 2015 11:02 AM
Tp'sfury
Aug 13, 2015 08:20 PM
maxcichon
Jul 31, 2015 06:35 PM
Crossfireconv08
Jul 30, 2015 12:11 PM
