amp connector
Old Jun 25, 2009 | 03:32 PM
typhoon55's Avatar
Default amp connector
I want to reattach a loose wire to the 12 pin amp connector. I had a fried amp due to water damage and am trying to reattach 2 red/yellow wires (power) which were coroded. I have to strip and reattach it but not familiar with this connector. It seems that there is some sort of metal that attaches to end of wire which is then pushed into plastic 12 pin connector?
How does wire stay secure?
Old Jun 25, 2009 | 06:59 PM
kurtisberry's Avatar
Default Re: amp connector
They are crimp on connectors. There are usually two tabs on the connector that are forced around the bare wire and smashed down with a special tool. There is usually a second set of tabs that crimp onto the wire insulation for strain relief. They are generally not re-usable, but you may be able to dig out the old broke off piece of wire and solder the wire back onto the connector. There maybe a barb tab on the side or top of the connector to allow you to get the pin out of the plastic shell.
Old Jun 25, 2009 | 10:50 PM
typhoon55's Avatar
Is there any resource for these connectors and or a picture of the actual crimp on pin?
Can I pull out individual wires and see the pin without destroying it?
It seems the water must have reacted with voltage in the 2 power wires and destroyed the pin attached to the wires
Old Jun 26, 2009 | 01:56 PM
typhoon55's Avatar
better photos...
What is the part number for the amp? I could not find a part numbers list . There used to be one on durango site but it seems to have changed
Old Jun 26, 2009 | 07:34 PM
Originally Posted by typhoon55
better photos...
As mentioned in a previous post these terminals have a barb on them that is pushed in by the socket body as it enters and springs back into position when it gets to a little pocket. This holds the terminal in the correct position, sometimes this little barb can be pushed in enough to allow the terminal to come out the way it went in. You may and I say may be able to insert a small screwdriver or something similar from the other side of the terminal housing and depress this barb.
If not you will have to buy a new plug and cut the good wires and crimp them onto new terminals. Obviously a socket from a wrecker would have all the terminals locked into position and you would have to splice all your wires to the wires in the plug from the wreckers.
Amplifier part number is: 05136097AA, I will recheck it.
Old Jun 26, 2009 | 10:14 PM
typhoon55's Avatar
Once the wires are inserted into the plastic connector from the factory, are they designed to be permanent so as never to be removeable?
It sounds like the barb is very difficult to release once in place.
I am thinking of making a modified connection for the 2 wires so i do not have to replace the entire connector. Just not sure how ...
Old Jun 26, 2009 | 10:46 PM
You could look for two terminals that fit the amp socket, solder them to the wires, insulate them and cut off the section of plug with the damaged terminals. They would fit the amplifier without the damaged connector getting in the way.
Old Jun 28, 2009 | 11:12 PM
typhoon55's Avatar
THX FOR THE SUGGESTION - I WILL TRY TO FIND TERMINALS SMALL ENOUGH TO FIT ON AMP AND then CUT OR DRILL OUT THE EXIST. PLASTIC CONNECTOR TO ACCOMODATE THE NEW TERMINALS.
according to local dealer, amplifier part number is #5189332AA but that seems to pull up a 07 crossfire with a price tag of $1800.
Old Jun 29, 2009 | 06:37 PM
typhoon55's Avatar
having a problem finding female quick disconnect connectors small enough to fit the male amp prongs.
Old Jun 29, 2009 | 09:05 PM
maxcichon's Avatar
I have the removal tool and a number of different crimp on AMP style pins. If you can get a close-up photo, I can send you a few pins to try. And if you promise to return the extractor tool, I can send that too. Let me know.
Old Jul 2, 2009 | 12:24 PM
typhoon55's Avatar
I am finding little on the correct amp style pins and / or avail. - what a pia!
I want to connect properly but may have to resort to just a bare wire type fix as dealer does not have a harness fix kit and the male prongs from amp are too small for any generic female connector I can find.
Does anyone have a old harness laying around?
Old Jul 2, 2009 | 01:12 PM
If you have one that is a bit too big, maybe you can massage it a little as they are only formed into shape from flat stock.
Old Jul 2, 2009 | 02:19 PM
typhoon55's Avatar
Evidently, the original pins to the power wires have disintegrated from mositure / water .
Whatever they were made of did not react well with water
syfi
Mar 28, 2026 04:14 PM
pioneer4x4
Mar 18, 2021 02:17 PM
ala_xfire
Sep 28, 2015 05:51 PM
mobilefitt
Sep 24, 2015 01:04 PM
bobbie
Sep 12, 2015 12:49 PM
