Black smog and 1 miter of fire From exhaust
Old Oct 27, 2009 | 09:33 AM
Rasim's Avatar
Unhappy Black smog and 1 miter of fire From exhaust
Guys, I have had black smog emitted out of my exhaust in kick down push moment, emission is not continued even you keeping hold acceleration pedal in the floor, just short emission.
That tells about rich Air fuel ratio, and that is definitely opposite of my opinion, because it started after I installed 178mm crank pulley this no tune which means I increase air boost and no fuel map ratio, I thought I would run with poor AFR not rich. The same issue with my friend’s C32 after installing 178mm pulley.
P.S I twice had 1 miter of fire when I test my car for max speed so I drove hard and at the end of 4th gear my friend running behind noticed that fire till I went to 5th gear, he was scared of thinking I might blow up.
I did not feel any power loss or something else.
Does anyone has an idea what the hell is that?
Old Oct 29, 2009 | 03:20 PM
Rasim's Avatar
Default Re: Black smog and 1 miter of fire From exhaust
Does any body answer me?
Old Oct 29, 2009 | 03:29 PM
GDC-SRT's Avatar
If you are getting flames out the tail pipe you need fuel .
That would indicate it is not a complete burn in the cylinders.
Most likely a rich condition, I believe when they tune these cars, they also advance the spark.
That is all I can tell you.
Old Oct 30, 2009 | 07:13 AM
Rasim's Avatar
That was before ECU tune and after LET tune, i got my sparks that is the same age as my car so 8 years old, may be problem with them.
Old Oct 30, 2009 | 09:23 AM
Stogey's Avatar
Yep....runnin rich dude ! Is it missing at idle ?
NeedsWings
70
Mar 24, 2023 09:48 AM
colin nicholson
U.K.
Aug 9, 2015 08:56 AM
rmcdaniel12
Aug 7, 2015 01:37 PM
cjfine
Jul 20, 2015 11:58 PM
Rusty475
Jul 13, 2015 10:03 AM
