Will This Work?
Old Feb 16, 2010 | 10:24 AM
Vegaslegal's Avatar
Default Will This Work?
Can someone tell me if this radio can be installed as a slide-in with matching plugs to the '08 Crossfire head unit set-up? I.e., can I do it in my garage, and even if not, if I buy the thing will there be any problem for an installer putting it in? See pics and diagrams.
Thanks so much in advance.
File Type: pdf
File Type: pdf
Old Feb 16, 2010 | 10:27 AM
Vegaslegal's Avatar
Default Re: Will This Work?
Somehow photo did not load. Here it is:
SUPER HOT ITEM!
Bluetooth and DIVX capabilities
Main Features:
-CAR In-dash DVD with 4.3" Wide TFT Colour LCD Screen
-Bluetooth with built-in microphone on the front panel
-One touch button to answer a phone call through your car speaker.
-Play directly your music on your cellphone via bluetooth.
DVD/DVD-R+/DIVX/VCD/MP3/WMA/MP4/CD-RW Compatible
-Built-in 4.3" High Resolution Digital TFT LCD color monitor
-Motorized Detachable Slide Down Front Panel
-Selectable view angle
-Built-in TV TUNER ( USA NTSC PAL M, N / Europe PAL I, BK, BG )
-USA/Europe Frequency Switch
-Support USB Drive for direct playback
-AUX-IN Video & Audio on the panel
Cable include to connect your IPod via AUX-IN
-4X50 W Max. Mosfet Amplifier
-AM/FM-MPX 2 Band Radio
-PLL Synthetized tuner
-Auto Store/Preset Scan
-30 Station Memory
-Picture Control: Brightness/Contrast/Colour/Tint/Reflection Size
-On screen display title, time, chapter, subtitle & angle
-Treble/Bass/Balance/Fader/Volume control
-Dolby Digital Coaxial outputs
-ALL Region DVD Playback
-PAL/NTSC Color system ( DVD Playback )
-Anti-Shock mechanism
-ESP ( Electronic Shock Protection )
-LO/DX & ST/MO selector
-Repeat/Intro/Random
-Clock Function
- Mute Control
-RCA Line Out
-Preset EQ
-SUB-Woofer Line Out
-A/V input & A/V output
-Rear Camera Parking input
-ISO Connector
-Remote Control
And Much Much More...
Old Feb 16, 2010 | 05:52 PM
kurtisberry's Avatar
Not enough info here. If it is a true single DIN it should fit. It is not plug and play. You will need a wiring harness to adapt the Xfire wiring to the headunit connectors. This needs to be assembled by hand, matching the correct wires from each together. I would suggest an installer if you don't know what you are doing.
Again, there is not enough information in the ad to determine if it will physically fit.
Old Feb 18, 2010 | 05:05 PM
GettinIt's Avatar
I cant see why it wouldnt work... appears to be a single din, plan on needing the wiring harness.
Not to sure about the brand though... Wouldnt mind picking one up myself because of the bluetooth capabilities, if its AD2P bluetooth, that way you can play music off you phone via blue tooth.. Great way to listen to Pandora in the car!!!
Doesnt appear to do GPS either...
Old Feb 19, 2010 | 03:05 PM
I am not trying to knock you, but I would not put this ebay crap in my car under any circumstance. If it is hundreds less than the other LCD units, there is a reason.....
Old Feb 19, 2010 | 03:39 PM
Jesus_Christler's Avatar
This unit's not the right color but it's got a larger, detachable screen AND gps.
5.6" 1 Din in dash Car Radio DVD Player GPS dual Zone
PNA
Nov 12, 2020 04:44 PM
Hoppy
Dec 7, 2018 07:36 AM
waldig
Jul 31, 2017 09:46 AM
waldig
Sep 2, 2015 11:02 AM
xfClifford
Aug 3, 2015 11:03 PM
