Alarm gone mad ... HELP
Old Mar 18, 2010 | 08:35 PM
sled driver's Avatar
Default Alarm gone mad ... HELP
Hi all, Firstly I am a long time lurker but first time poster here on the forum. Primarily because I have found all the answers I need without needing to ask questions. Thanks for all the help.
Unfortunately my '04 Limited is losing its mind this evening. The alarm has gone off 3 times in 45 minutes, while sitting in a closed locked, level garage. I searched and found a couple threads, but I couldn't find an answer as how to deal with the problem effectively. I really do not want to go to the dealer and give them any of my hard earned money, but I am not comfortable ripping out and reinstalling a whole electrical system.
Any help, advice or witty sarcasm will be appreciated!
Old Mar 19, 2010 | 12:05 AM
tighed1's Avatar
Default Re: Alarm gone mad ... HELP
Yo Lurker. I'd start by looking at the battery.
Is it the original?
Have it tested for free at Autozone (or similar). Our cars do weird things when the batteries start going out.
Old Mar 19, 2010 | 12:34 AM
Is it the original?
+1
My alarm went off when I opened the door of the car the other day, at the time I thought it was a fluke. The next day i decided to start the car as it had sat for two months or so without being started or having the battery charged, when I started it the wing went up. It is a new battery and was just a little flat and I think (and hope) it caused both events.
Old Mar 19, 2010 | 08:24 AM
bmorgan's Avatar
+1 You need to start lurking for a battery.
Old Mar 19, 2010 | 08:32 AM
YEP!
With any Lurk, that's the issue.
Half the electrical issues can be solved by disconnecting the battery for a few minutes and then re-connecting.
Except, of course, a weak battery.
He did ask for it guys.
Quote SLED DRIVER
"Any help, advice or witty sarcasm will be appreciated!"
Welcome newbie!
roadster with a stick
Old Mar 19, 2010 | 09:59 AM
fastfunfor2's Avatar
Another possibility is water in your trunk. Underneath the hard foam block in the floor of your trunk (passenger side) is an alarm control module as well as your central locking module. Under the car and covered by undercoating is a round rubber plug about the size of a dime. There is one for both trunk tubs, at the lowest spot. Clean away the undercoating and pry the plug out. If any water comes out you've got two problems. First, you have a leak. Second, your modules will be damaged and are very expensive to replace.
Its worth a look.
Old Mar 19, 2010 | 11:22 AM
Its worth a look.
I thought they were for use as live bait wells when you went fishing and the pump was an aerator, silly me.
Old Mar 19, 2010 | 11:24 AM
bmorgan's Avatar
face palm! Damn, why did I not think of that before? Great tip.... Thanks!
Oh, and have you ever fished for rabbit? I have lots of rabbits in my back yard near the wood line. I can sit on my balcony with rod/reel in hand, bait it with a piece of carrot.... cast, and viola!
Old Mar 19, 2010 | 11:54 AM
rcompart's Avatar
Don't let the PETA people find this out. LOL
Old Mar 19, 2010 | 12:00 PM
bmorgan's Avatar
Maybe I should have started it out with....... I am not saying this happended, but if it did! LOL Oh, and in the fight department, a large mouth bass dosn't have anything on a pissed off rabit.
Old Mar 19, 2010 | 12:04 PM
rcompart's Avatar
ROTFLMAO!!!
Old Mar 19, 2010 | 12:38 PM
Thanks for the advice, I will start with the battery and trunk (seems easy and cheap) So far the alarm has only activated the 3 times last night. I am keeping my fingers crossed, otherwise my wife (it is her daily driver) is going to have some very angry co-workers.
Also thanks for the advice on how to control the rabbit population, I personally prefer my AR-15 or 12ga ... depending on my mood!
Old Mar 19, 2010 | 12:45 PM
rcompart's Avatar
This one does the job quite well too. Maybe a little too well. LOL
Old Mar 19, 2010 | 12:55 PM
bmorgan's Avatar
Aw Hell, anyone can shoot a rabbit. Now reeling in a pissed off 5 pounder with 3lb test line, now that's sport. What is real fun is putting a couple drops of tobasco on the carrot. You gotta be quick to set the hook, but if you do...... look out! That sonofagun will give you a fight like a champion bull on steroids.
tighed1's Avatar
Hey Rudy. That's pretty sweet. What is it?
Can we do a group buy?
Old Mar 19, 2010 | 12:58 PM
rcompart's Avatar
That my friend is a Heckler & Koch MP5A2. It was tough enough getting this one so no, we can't start a group buy for it. LOL
Old Mar 19, 2010 | 01:21 PM
midlife chrysler's Avatar
+1 on the battery.
See my posts about the alarm and key fob situations...also, when I finally got her boosted back up (took two batteries to crank her over) I also noticed the spoiler was up - unasked for...I guess low battery really does cause some "ghosts in the machine"...
Old Apr 1, 2010 | 06:42 PM
Argh! So mine is going off again. Unfortunately I am in Florida and my wife is in Michigan with the car. Is there a quick fix that I can explain to my wife over the phone. I am thinking something along the lines of pulling a fuse or cutting a wire. It does not need to be permanent just to silence the siren, I am less concerned about the flashers etc going off for a few minutes as long as it is silent. Any help will be appreciated.
Old Apr 1, 2010 | 08:21 PM
Rudy, you need a folding stock...or colapses....I will work on that for you...lol
Old Apr 1, 2010 | 08:39 PM
A collapsible stock makes everything better. But it will really hurt your accuracy especially from the hip with that MP5, not that accuracy matters with a 9mm sub machine gun
Anyways any ideas on this alarm issue? Is there a fuse to pull?
