New System all kenwood
Old May 4, 2010 | 10:22 AM
94Bravada's Avatar
Default New System all kenwood
Hi I have taken the plunge and started working on the system in my car. I relocated the centeral locking system and hush matted the whole trunk. I have also installed the kenwood deck and navigation.
This weekend I build the wooden part of my box.
I am planning on making the bottom of it out of fiberglass to mold to the bottom of the car. The local shop that I am friends with is doing the fiberglass for me cheep, I love wood working but man do I hate glass work haha.
My whole system is going to be all kenwood, my deck is the KVT-696 with the add on nav. ,
The door component speekers are KFC-X1730P
I am Amping the door speekers and the subs with two amps
The one is the XR-4S for the doors
The second is the XR-1S for the subs
The subs themselfs are two KFC-XW1000F shallow mount 10"
So what do you guys think of my ideas and plans, everything is Kenwood Excelon so it is all there top of the line stuff
Old May 4, 2010 | 10:52 AM
TaReGt's Avatar
Default Re: New System all kenwood
Everything sounds good except the shallow mount subs. Go for the regular ones, they sound much better.
Old May 4, 2010 | 11:37 AM
///SilverSaphRT6's Avatar
Looks good.....keep us updated.
Old May 4, 2010 | 02:03 PM
Very nice build so far, but depending on your dimensions for the sub boxes, I would also suggest going with full size subs. I can understand if the boxes are already made for the shallow ones, but if not, go full size and you get much more punch than the shallow ones IMO.
Old May 4, 2010 | 11:44 PM
Beaner's Avatar
How much higher will the floor be? it looks roughly 2" in your pic. If you relocate that little black box with the foam around it you are easily able to fit a full size 10" in each side. these are the ones I put in my car with the floor raised 2" Clarion Canada | PXW1052 (Outside Dimension 10 3/8" Mounting Depth 5 1/2")
Ohh I was just checking out the specs on you amp and subs, check out the RMS.
Sub - Power range: 50-250 watts RMS @4 ohms
Amp - 600 Watts (RMS) x 1 @ 4ohms
Might want to get a smaller amp or a little more powerful sub. Bigger is not always better.
Just my 2¢
Old May 5, 2010 | 07:26 AM
94Bravada's Avatar
When I started I was planning on having the box level with the floor then I got the idea to raise it up 2" so I can flush mount the amps in the floor too I never went back to see if normal subs would fit in now you are all probably right they most likely fit now thanks for the great ideas. My highs come with crossovers has anyone put crossovers in the doors? Is there room with the airbags? Pics would be great thanks
Old May 5, 2010 | 07:31 AM
Beaner's Avatar
Originally Posted by 94Bravada
... My highs come with crossovers has anyone put crossovers in the doors? Is there room with the airbags? Pics would be great thanks
Yes there is room in the doors. I did it. I will add a pic to the gallery right now
Old May 5, 2010 | 08:05 AM
94Bravada's Avatar
[color=#660000]]- CrossfireForum.org Gallery
Thanks good to know they will fit. I had never seen your new system thats pretty awesome look a lot like what i am planning on doing, and where did you get those sub covers those are awesome haha
Old May 5, 2010 | 09:08 AM
Beaner's Avatar
I made them
Old May 27, 2010 | 11:14 PM
94Bravada's Avatar
Just an up date I have the box all made and in and I ordered everything today so it should be all in shortly. Also I got 2 sets of highs I am planning on puting the second set in the back for show
Old Jun 15, 2010 | 10:17 AM
94Bravada's Avatar
Its almost finished I have a plexiglass peice that goes inbetween the amps and subs that should look pretty cool. I also have a second set of highs that i am planning on mounting in the truck on the carpet over the gas tank. Here are the pics of it so far I did end up going with the shallow mounts but they sound really good
Old Jun 15, 2010 | 10:34 AM
Thirteendog's Avatar
Okay several questions,
1st How did the head unit work with the stock set up? It looks like you used it for awhile before finishing your project.
2nd Can you put anything in the trunk now? I'm assuming you wouldn't want to set anything on the speakers/Amps (I'm a total noob at car audio)
3rd I want to see pics of the rest of your set up. I've been looking at your head unit.
Oh btw Looks fantastic
Old Jun 15, 2010 | 11:34 AM
Look SICK!! Very nice!
Old Jun 16, 2010 | 09:30 AM
Looking very good Bravada.
PM me if you want a good suggestion on where to put that second set of components....
Old Jun 17, 2010 | 04:01 PM
94Bravada's Avatar
The head unit worked really good with the stock set up it made the factory speakers sound a lot better as for the truck i was planning on making a cover that would sit over top of everthing so i could still put stuff back there and i will post pics of the rest of the stuff in a bit most of it is covered tho
Old Jun 17, 2010 | 04:08 PM
94Bravada's Avatar
Old Jun 17, 2010 | 04:41 PM
ZAHANMA's Avatar
[insert dirty joke about 'enormis' here]
...looks good.
TerryR
Dec 13, 2019 03:27 PM
vnrcoop
West Forum
Oct 4, 2018 01:09 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
Ed Mahoney
Sep 8, 2015 08:36 AM
