Aftermarket gauge questions
Old May 26, 2010 | 10:47 PM
KBallschmiede's Avatar
Default Aftermarket gauge questions
Hey guy,
YES! I did search this. I want to run a oil temp, oil pressure, and a scan Aeroforce gauge.
1. Where should I look to get a oil temp reading?
2. If I use the stock test point that you guy use for the oil pressure, and can I make a "t" and get my temp sender there as well as my pressure sender?
Thanks in advanced,
-Kevin
Old May 28, 2010 | 01:24 PM
Default Re: Aftermarket gauge questions
ouch no reply? BUMP
Old May 28, 2010 | 02:45 PM
That won't be a very accurate oil temp reading, IMO.
Pressure, sure, but not temp. Not sure where I'd go for temp.
Old May 28, 2010 | 04:16 PM
Infinite's Avatar
oil pan, only way to go
Old May 28, 2010 | 04:43 PM
That was my thought. I put an oil pressure gauge and oil temp gauge on my 25 hp Kohler-twin in my lawn mower. Used the conventional port for the pressure, but for temp, used one of the TWO drain plug holes.
Worked like a champ.
Old May 28, 2010 | 05:06 PM
NeedsWings's Avatar
look into the zeitronix / dashdaq setup as it would be much more beneficial for you. it woudl do everythign you want and then oodless more
Zt-2 + DashDAQ Touch Screen Display and Datalogger Combo
Zeitronix Fuel/Oil Pressure Sensor Add-On
Zeitronix Fluid Temperature Sensor
TerryR
Dec 13, 2019 03:27 PM
Sterling57
Apr 11, 2016 06:11 PM
jimf
Oct 10, 2015 10:22 AM
Charlesl
Sep 30, 2015 10:46 PM
brandoni
Sep 30, 2015 07:48 PM
