For those that gutted an NA muffler?
Old Aug 31, 2010 | 09:49 PM
Default For those that gutted an NA muffler?
I am trying to find something midway between the current Magnaflow I have and the stock system for loudness.
I have an OEM system on the way. I want to only cut a hole large enough for what is needed. Would only removing the packing get me what I want? Or must I remove the rear baffles as well?
Old Aug 31, 2010 | 10:02 PM
Infinite's Avatar
Default Re: For those that gutted an NA muffler?
I gutted mine, you're gonna have to cut about a 10x10 hole in the top of the muffler.
I didnt remove everything, I removed the packing and the perforated rear section, then had the cover welded back on
Old Sep 3, 2010 | 06:19 PM
32krazy!'s Avatar
why not use an amg muffler? free flowing and has a nice sound. i have 1 i bought from 240m3srt, no tips but complete amg srt-6 muffler
Old Sep 3, 2010 | 07:10 PM
waldig's Avatar
Talking Re: For those that gutted an NA muffler?
You can see my gallery where I gutted the srt muffler and then removed it cause it was a bit louder but no better. I rewelded the stainless cover and all with little gain. I then added the stainless 4" wye pipe with better sounds and less weight. Woody see the photos.
WEEKEND WEEKEND
WEEKEND WEEKEND
Old Sep 5, 2010 | 08:37 PM
clem05XF's Avatar
If you have a magnaflow muffler, please try this first. Cut the bottom off a coke can and press it into one side of the magnaflow muffler. Try it like this, if too quiet, punch holes in the can bottom with a long rod until you get it to sound like you want.
Best regards,
Old Sep 8, 2010 | 04:38 PM
I picked up a second OEM system from a forum member to do this. Also thanks to Shawnkey for posting his picture of a muffler without the shell. It helped a bunch.
I used a cutoff tool to get the access. It took two wheels to get thru the stainless. The cut on three sides is aprox 4" x 13". The fourth side I used as a hinge. In the next day or two it will be welded back together.
Two different materials are used in this muffler. Long strands of steel wool wrapped the baffles. The remaining area was filled with fiberglass insulation.
Old Sep 9, 2010 | 08:50 PM
Got home today with some time to switch out the exhaust. Removed my Magnaflow very easy. A little tough getting the rear rubbers back on the OEM even with the hanger tool, but eventually it went on.
Couldn't wait to start it up and take a test drive.
Guess what?
It is just as quiet as the OEM with all the stuffing! NO DIFFERENCE.
Now to figure out plan B I guess...
James
Old Sep 9, 2010 | 09:01 PM
32krazy!'s Avatar
plan b is an amg muffler!
Old Sep 9, 2010 | 10:59 PM
Infinite's Avatar
I experienced the same problem. Took out that kidney shaped baffle and it definitely sounds deeper
Old Sep 9, 2010 | 11:33 PM
Yea I asked about that in post #1. Thanks for the late reply.
Old Sep 9, 2010 | 11:54 PM
Plan B:
Open er back up and remove the baffles now ??
Old Sep 10, 2010 | 07:29 AM
Grumps's Avatar
James
It only takes a minute or two to install the OEM if you take the rubber hangers off the car and install on the muffler first. Then with a little dish soap on the car hangers you can reach up and push the rubber hangers on with your thumb.
Old Sep 10, 2010 | 04:06 PM
Plan B:
You are on the same train of thought as me. Next week.
Old Sep 17, 2010 | 08:53 AM
G3arh3ad's Avatar
I'm probably too late but anyway. I opened two stock mufflers and here's what I did (sorry no pictures available):
Muffler 1:
- removed all the packing - everything
- removed the perforated kidney shaped section
- in the section where the packing material has been: drilled 3 additional holes of 0.4in diameter in every tube (the perforated AND the unperforated)
Muffler 2:
- removed 50% of the packing
- in the section where the packing material has been: drilled 2 additional holes of 0.3in diameter in the perforated tubes and 1 hole of 0.3in diameter in each unperforated tubes
Here's how I think the stuff changes sound/noise:
Packing: Noise damping at higher rpm's and roughness of sound
Kidney: Overall noise level
Holes: The holes in the unperforated tubes have the greatest effect - it's like avoiding the muffler since a short connection between inlet tubes and outlet tubes is created
Both Mufflers are only noticable when you step on the gas - at cruising speed they're pretty close to stock. Muffler 1 has a bit deeper sound is overall louder than Muffler 2.
Both are nowhere near a Magnaflow regarding noise level but also regarding sound. On the other hand are both mufflers better than stock in both aspects.
Old Sep 17, 2010 | 10:39 AM
waldig's Avatar
Guyz I said that the gutting of the muffler made no difference to me, I cut out the entire tubing and baffel without gain. Thats why I went to my wye pipe design. Woody
Crossfire modifications - CrossfireForum.org Gallery
Photos of muffler. Enjoy
Old Sep 17, 2010 | 12:30 PM
G3arh3ad's Avatar
Am i missing something here? To me it looks like the SRT-Muffler is a different layout then the N/A-Muffler. And if i remember correct the SRT has an additional resonator too. So basically: What works for the SRT may not work for the N/A and vice versa.
When you go full throttle both modified N/A mufflers I described above sound different/louder compared to a stock muffler. But the sound isn't as deep and loud as a Magnaflow - and it's certainly not as refined as the Magnaflow catback.
Old Sep 27, 2010 | 07:19 PM
Well guys, no matter what I did to the OEM muffler, I did not like the sound. The noise level wasn't bad, just sounded terrible to me. Stuffed everything back in there, welded her back up and as good as stock, maybe quieter.
So reading on another forum (sin?), wrapping an aftermarket muffler will actually quiet down the interior noise in the car. So that is what I did. It is raining so I didn't take my clean car out of the garage yet to see the results. It does sound different when I rev it. Time will tell, and at the Dragon. James
Old Sep 27, 2010 | 08:03 PM
32krazy!'s Avatar
check mine out at the dragon james. oem amg muffler with res and sec. cat delete. x pipe in place of y pipe. quiet in the neighborhood and screams at wot
TerryR
Dec 13, 2019 03:27 PM
o55ie18
Oct 5, 2015 05:50 PM
Big_Country
Sep 22, 2015 03:47 PM
Sep 13, 2015 02:12 AM
Fildo Dog
Jul 6, 2015 05:20 PM
