license plate bulb replacement?
Old Sep 20, 2010 | 04:19 PM
Alzilla's Avatar
Default license plate bulb replacement?
Has anyone else had problems finding the right bulb that goes in the hatch just about the license plate? I'm pretty sure it's a 6418 but I can't find that bulb in any auto parts stores. Does anyone have any recommendations on where to find it online?
Also, how does one get access to the front parking light? It looks like I have to take the headlight out to get at it. I can get the top two screws out but it won't budge. Is there another screw on the bottom of the headlight somewhere holding it in place?
Old Sep 20, 2010 | 04:33 PM
robby363's Avatar
Default Re: license plate bulb replacement?
A C5W will work. It's the same as a 6418.
Old Sep 20, 2010 | 04:49 PM
MikeR's Avatar
Go here....
https://www.crossfireforum.org/forum...ollection.html
and download the service manual.... this will give you all the info you need on how to remove the lights..
If you cant find the license plate lights at your parts store.... just look them up online and order them.. they should be easy and cheap....
Old Sep 20, 2010 | 05:09 PM
robby363's Avatar
You can change the parking light without removing the whole headlight. It can be done with long needle nose pliers and patience. Use the pliers to turn the bulb socket counterclockwise and pull it out and install the same way using the pliers and turn clockwise.
Old Sep 20, 2010 | 07:30 PM
Alzilla's Avatar
Thanks guys! Found what I needed!
Old Dec 10, 2012 | 01:46 PM
Fjp3105's Avatar
Can you please confirm what bulb you used. And where you purchased it.
Thanks,
FJP
Old Dec 10, 2012 | 08:35 PM
Even a better option to replace the license plate lights
Originally Posted by JimmySkullz
I dont know if anyone else posted these, But I have them in both my Crossfires, over a year now with no problems.
A little bit of a tight fit but they work perfect.
2 License Plate LED Kit No Error Mercedes W211 S211 E Class W219 CLS R171 SLK 55 | eBay
LED license plate bulb -- full assemblies
Old Dec 10, 2012 | 09:21 PM
Fjp3105's Avatar
Thanks. Ordered.
2004_
Jul 9, 2025 12:39 AM
PNA
Nov 12, 2020 04:44 PM
Hoppy
Dec 7, 2018 07:36 AM
Vazgen
Aug 11, 2015 01:24 PM
autumnmass
Jul 30, 2015 01:06 PM
