Chirping Alarm Siren (lock/unlock)
Old Dec 15, 2010 | 11:52 PM
Question Chirping Alarm Siren (lock/unlock)
... Deleted ...
Old Dec 16, 2010 | 11:06 PM
magneticred's Avatar
Default Re: Chirping Alarm Siren (lock/unlock)
I found it was much easier and costs next to nothing to follow the instructions here:
https://www.crossfireforum.org/forum...lert-tone.html
It works very well. I think you would be pleased.
Old Dec 17, 2010 | 02:34 AM
corfire's Avatar
Thumbs up Re: Chirping Alarm Siren (lock/unlock)
Most who have tried it, like it.
Old Dec 17, 2010 | 04:45 AM
Steve - UK's Avatar
Is it possible to simply parallel another siren (the newer one that chirps when you lock/unlock) into the harness under the hood instead of removing the cowl and swap modules? If my memory serves me well, the replacement module mounts differently and it is a little pita to delve into the cowl area. Looks like the three wire harness comes right out into the engine bay/firewall area (please correct me if not so). If the three wires are power, ground, and signal then maybe the simple splice can allow two sirens to be present. Would the added circuitry screw up the system to the point the system fails? Will the fuse handle two sirens (original and modified one)? Finally, will the modified one chirp if spliced in with an unmodified (old) one which may be easily located in the engine compartment?
Thanks for any insight on this guys n gals!
Once you have verified that the harness you see is the feed for the siren, I would be tempted to fit the new unit in the engine bay and take the wiring straight to it. You could chop the wiring, - leave the original siren in place disconnected. use some push connectors, so you could re connect the to the old siren when/if you part with the car. If you can see the colours of the wires, you can check against wiring diagram to make sure before starting. Removing the wiper arms and trim to get at the siren is a pain! Let us know how you get on.
Old Dec 17, 2010 | 04:05 PM
Question Re: Chirping Alarm Siren (lock/unlock)
... Deleted ...
Old Dec 17, 2010 | 04:30 PM
Steve - UK's Avatar
Just looking at my car today - and yes I agree, not wise to chop anything. I reckon it's just as easy to remove the cover and replace the original siren unit with the more up to date version of the siren. There are the 7 screws to release the cover, and of course the wiper arms need to come off. These can be tight and difficult to remove, put a simple and cheap puller can be used to release them if needed.
I have had a little buzzer attached to the flasher relay in the fuse box for a couple years to get the desired bleep bleep bleep when locking. But the right way is to fit the undated siren and I will do this when i get my hands on one
Old Dec 17, 2010 | 08:47 PM
corfire's Avatar
I do not want wires spliced all over the place nor do I want a buzzer wire wrapped around relay pins. If I cannot just parallel the new chirping siren outside the cowl/under hood, then I will just go ahead and install it in the originals place.
I would not advise trying to connect two sirens on the same circuit. So, the replacement seems to be what you should and want to do. However, I have had the radio shack buzzer (tone mod) installed for almost three years without any problems with just solid wire wrapped to the relay pins, but they could be soldered. The mod can be removed in just a few minutes if one whats to restore the circuit to the original condition. It really is a simple inexpensive little mod.
Old Dec 18, 2010 | 08:51 AM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Not to confuse you but:
Although my car already had the siren install (not loud enough), I added the Radioshack piezo as descrbed in this thread by soldering it to the relay pins.It was alot easier than getting under the car and splicing wires where the splices would be subject to the elements. I removed the relay and soldered everything on the bench and then simply re-installed, routed the piezo wires through the rubber slit grommet then double sided taped the buzzer to the outside of the relay box cover. Works great. "Just saying"
Old Dec 18, 2010 | 09:42 AM
... Deleted ...
Old Dec 18, 2010 | 10:08 AM
... Deleted ...
Old Dec 18, 2010 | 11:40 AM
corfire's Avatar
Exclamation Re: Chirping Alarm Siren (lock/unlock)
I don't know how many times I have to say I do not like nor will ever do that buzzer mod in my car. Hopefully, this direct statement will clear that up.
NO THANKS, I DO NOT WANT NOR WILL I EVER PUT A BUZZER IN THE RELAY WIRING!
Was not trying to antagonize, just trying to be helpful. Isn’t that what we do on the Forum?
Old Dec 18, 2010 | 12:00 PM
... Deleted ...
Old Dec 18, 2010 | 12:50 PM
Exactly what I was trying to do as well.
Sorry can't help you with the circuitry issue.
Old Dec 18, 2010 | 01:40 PM
GDC-SRT's Avatar
Where is Pizzaguy when you need him?
He has a good understanding of electronics.
I would put him near the top for having an answer for you.
Old Dec 18, 2010 | 02:16 PM
... Deleted ...
Old Dec 18, 2010 | 03:57 PM
Hawk Monster's Avatar
Replacing siren with a new one took 15 to 20 minutes.
Old Dec 18, 2010 | 07:22 PM
Smile Re: Chirping Alarm Siren (lock/unlock)
... Deleted ...
Old Dec 18, 2010 | 08:14 PM
I had the new one as a replacement. Use a little of WD40. Where ear plugs when you remove the old siren. It is a safety feature. Mine really blasted. Don't do it early in the AM or your neighbors may get really annoyed.
Old Dec 18, 2010 | 08:22 PM
Why did they go from AA to AB model? My guess is that it was a Mercedes change rather then a Chrysler issue.
Old Dec 18, 2010 | 08:31 PM
I think you are making a mountain out of a mole hill. Bite the bullet, buy the new part and install it. No messing or modifying your OEM wiring harness. I changed out a co-workers at lunch time in less than 20 minutes in the parking lot.
