Power Steering Flush
Old Jan 6, 2011 | 10:16 PM
edgehead2000's Avatar
Default Power Steering Flush
Hey guys,
I want to do a power steering flush on the '04 Alabaster but am having trouble finding the return hose. Right now, I'm going off what is posted on the MBWorld (C320 2002 Power Steering Flush DIY - MBWorld.org Forums) and what is posted in repair manual.
I'm a pretty good DIY'er but do not want to pay for somebody else to touch my car. Could use some of the forum's expertise. Thanks.
Old Jan 6, 2011 | 10:47 PM
Default Re: Power Steering Flush
Originally Posted by edgehead2000
Hey guys,
There are only two hoses, the fluid transfers directly from the reservoir to the pump. It passes through the flange at the top of the pump, item 4 in the diagram is the retainer that locks the joint.
Hose #6 is the return hose.
Old Jan 6, 2011 | 11:34 PM
Umm... Is that right? The manual is a bit confusing because I don't think they clarify where the return hose is.
They list their instructions as:
1. Remove the accessory drive belt (1). Refer to Page 7-45.
2. Remove the oil in the power steering reservoir (5).
3. Remove the power steering supply line (6) from the reservoir.
4. Remove the return hose from the power steering pump.
5. Remove the high-pressure hose (2) from the power steering pump.
6. Remove the power steering pump by removing the two bolts (3) attaching it to the engine block.
7. Remove the reservoir if necessary, by pressing out the c-clip (4) using a suitable tool.
The only hose I see on the pump is the High-Pressure Hose.
Old Jan 6, 2011 | 11:56 PM
I agree, but the hose #6 comes from the radiator and another hose comes from the steering gear and goes to the radiator.
The fluid leaves the reservoir via that flange and goes directly to the pump, exits the pump via the high pressure hose going to the steering gear, exits the steering gear to the radiator and returns from the radiator to the reservoir via hose #6.
You can see that hose #6 comes from the radiator.
I think they have an error in their write up.
Old Jan 7, 2011 | 12:28 AM
THANKS A LOT!!
I knew I wasn't crazy. This is why I love this forum.
So, to change the power steering fluid:
1. Siphon out the reservoir
2. Unscrew the return hose (aka supply line) from the reservoir and route to empty container
3. Block reservoir to return hose opening with something (suggestions? )
3. Put some fluid in the reservoir
4. While car is lifted, turn steering wheel left and right to its limits up to 30 times
5. Refill reservoir until full and no air is in the system
6. Repeat #3-5 until fluid does not settle anymore and all old fluid is purged into container
Sounds easy enough. Thanks!
Old May 19, 2016 | 12:06 AM
Sweet2002's Avatar
I have a new reservoir and o-ring but what about the c-clip? I think this is where the leak is or am hoping it nis as it is the easiest to access. Where can I get a c-clip or is it reusable? Anyone?
Old May 19, 2016 | 08:45 AM
C-clips hold things together and in contact with one another, they do not act as seals. If the part is not cracked then it would be OK to use, is it steel or plastic?
Old May 16, 2022 | 07:24 PM
BrushRoadster!'s Avatar
So, does the Serpentine belt need to be removed for this?
2 graphics say to remove it, and then one doesn't say anything about it at all. It appears that Edgehead's post is the closest to correct. But don't you need to have the engine running? Or do you just turn the steering wheel manually with the engine off?
Also, it says to do this 35 times lock to lock? How much fluid is required, based on it being constantly lost into the waste container?. I ordered 2 liters of Pentosin, but I am thinking I may need 2 more liters, or even 6, to go for 35 cycles of the steering gear. Anyone who has done this, please tell me what your fluid consumption is per cycle, and how much total Pentosin you needed to complete the flushing cycle.
Does anyone have the MB part numbers for the hoses? Since I am doing this, I would like to install all new hoses in my power steering system. My car is now 18 years old, and I doubt any of them have ever been changed, especially with only 30,000 miles on the vehicle.
Thanks, everyone!
Old Feb 24, 2025 | 01:27 PM
THETESTER's Avatar
Thanks, everyone!
Did you manage to change the fluid. Any issues crop up?
Old Feb 24, 2025 | 08:41 PM
I just replaced the power steering reservoir and flushed the fluid about a month ago.
You do the flush with the engine off. You'll need a second person to turn the wheel while you add the fluid until it runs clear.
If anyone is interested, here are links to my post. It's in two parts.
Power steering reservoir & flush Part 1
Power steering reservoir & flush Part 2
Old Feb 25, 2025 | 05:34 AM
THETESTER's Avatar
Many thanks, much appreciated.
I saw that 99% of people turn the steering wheel to "pump" out the old fluid. I have seen one method were the fluid is vacuumed out. Is this a good or bad method?
Old Feb 25, 2025 | 10:16 AM
Nelson G's Avatar
Take a look at this video:
Old Feb 25, 2025 | 10:41 AM
THETESTER's Avatar
Originally Posted by Nelson G
Again, many thanks.
Still wondering if I should use the steering wheel to remove the old fluid or use a vacuum pump.
Old Feb 26, 2025 | 12:44 AM
Originally Posted by THETESTER
Again, many thanks.
The steering wheel method worked well for me. You won't get as much out with the vacuum method in my opinion.
Remember to do it with the engine off.
Old Feb 26, 2025 | 05:29 AM
THETESTER's Avatar
Steering wheel it is then.
Thanks everybody
Old Feb 26, 2025 | 10:02 AM
It's easier if you lift the front wheels just a bit off the ground.
Old May 16, 2025 | 01:00 PM
THETESTER's Avatar
Power steering flush completed today.
New reservoir/expansion tank and gasket fitted.
I followed the suggestions about lifting the wheels and use the steering wheel to "pump out the existing fluid". No issues at all. (It took longer to jack both sides up than pump out the fluid!!).
For other European / UK members the reservoir/expansion tank is available from Autodoc in Germany. NOTE:- the reservoir/expansion tank DOES NOT come with the gasket.
The part number of the new unit was an exact match to the existing part:- Part number if ordering from Autodoc is 22358-01 (Lemforder). Their online system will say the part does not fit the Crossfire, but fits Mercedes.
Any questions, please ask away.
Old May 16, 2025 | 09:49 PM
I'm glad to hear that all went well! Thanks for the update.
BlkCell
Mar 11, 2026 09:54 PM
SRT6 Gang Member
Dec 9, 2022 11:42 PM
JeffS
Mar 21, 2021 07:29 PM
FUBU
May 8, 2015 04:49 PM
itsky
Jan 16, 2014 07:52 PM
