installed eurocharged 181 pulley, car won't start
Old Feb 5, 2011 | 06:07 PM
Holycrap's Avatar
Default installed eurocharged 181 pulley, car won't start
I have triple checked everything. Since eurocharged does not provide instructions a fellow memember sent me the let pulley instructions which helped a lot. But im sure there are some differences. Timing seems to be off. It cranks up hesitates, and dies down. what should i be looking for???? Thanks
Old Feb 5, 2011 | 06:16 PM
MikeR's Avatar
Default Re: installed eurocharged 181 pulley, car wont start
That is odd... just swapping the crank pulley shouldn't cause your problem.... unless maybe the pulley is slipping on the crank???
1. did you get the new pulley seated all the way?
2. did you use a new bolt?
3. did you get the bolt tightened to spec?
That is all I can think of that could go wrong with the swap....(other than damaging the front seal)...
Keep us posted....
Old Feb 5, 2011 | 07:46 PM
Holycrap's Avatar
Well now that u mention it. I used some pb blaster to get the crank bolt out so when i put in th new crank pulley some of it might have gotten on it. I just talked to jerry, he said i should check the flywheel since thats how i got the bolt off. Whats should i check for on the flywheel?
Old Feb 5, 2011 | 11:44 PM
Surely the car would start if the belt was slipping, and nothing appears to have been done to affect the timing.
Old Feb 6, 2011 | 11:34 AM
Holycrap's Avatar
Checked the fly wheel. It rotates when i try to crank it up. Checked all vacuums. It does not seem like the pulley is slipping. Any way to check if i installed the idler pulley wrong, or the crank? I didnt put it in the oven because it was a perfect fit. Should i have done that? Anything else??
Old Feb 6, 2011 | 11:46 AM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Did you check your belt routing?
see srt6 diagram here :https://www.crossfireforum.org/forum...y-diagram.html
Old Feb 6, 2011 | 11:50 AM
Holycrap's Avatar
yes that was the first thing i did. it was included in the instructions
Old Feb 6, 2011 | 11:54 AM
Holycrap's Avatar
Just in case its the crank postiion sensor, can someone tell me where it is locoted and how to get CEL codes from the dash. i know there is a way of doing it but i had it saved on my old comp. thanks.
Old Feb 6, 2011 | 11:55 AM
sounds electrical,,you could have knocked off something electrical ,,unplug and replug all plugs near where you were working. jim
Old Feb 6, 2011 | 11:56 AM
This is just a shot in the dark, but could the battery be weak from leaving a door open or light on while you worked on it. Enough to crank it but not enough to sustain...as I've read really strange things can happen when the battery is weak.
I know its a long shot but worth considering????
Old Feb 6, 2011 | 12:12 PM
Holycrap's Avatar
took ur advice and it did not help. i have reset the battery a few times also. its throwing a code. can anyone tell me how to get the codes from the dash. thanks
Old Feb 6, 2011 | 01:25 PM
tunaglove's Avatar
Default Re: installed eurocharged 181 pulley, car won't start
Get a cheap scanner from Wart Mart, and go from there. Stop guessing and wasting time. Once you get the code we will know what to do.
Old Mar 8, 2011 | 06:44 PM
dinasrt's Avatar
Well?? I'm curious what the problem turned out to be?
Old Mar 8, 2011 | 08:29 PM
You must have missed the later posts. Here's where it gets messy ....................https://www.crossfireforum.org/forum...on-sensor.html
and then it get downright fugly
......https://www.crossfireforum.org/forum...-flywheel.html
Old Mar 9, 2011 | 01:33 AM
dinasrt's Avatar
I did miss seeing this, and like you said...... Holycrap!! Damm it man, sorry to here about this.
roychez
15
Aug 31, 2022 01:11 AM
foxy1305
U.K.
Jan 1, 2020 11:41 AM
smmanley1996
Sep 4, 2015 04:40 PM
Keepmeinmind13
Jul 10, 2015 01:05 AM
carmax
Jun 18, 2015 01:30 PM
