swap a srt6 engine and trans in an NA coupe
Old Mar 7, 2011 | 11:01 PM
rmaier's Avatar
Default swap a srt6 engine and trans in an NA coupe
I have the opportunity to buy a complete 2005 SRT6 that was wrecked in the front. I already have a 2004 coupe...I know I will need the wiring harness and computer etc as well as the trans and accessories. Any other considerations? Any thoughts or suggestions would be helpful.
Old Mar 7, 2011 | 11:14 PM
LantanaTX's Avatar
Default Re: swap a srt6 engine and trans in an RA coup
If you change the trans which is a good idea, get the rear end and transmission control unit. Get everything unique to the SRT such as heat exchanger, plumbing, pump remote mount and plumbing for the smog pump. You might even want to grab the dash and ignition and key just for fun as well as the front and rear calipers and rotors. Might even grab the shocks, springs and wheels and then send the rear hatch and body contol module to me.
Old Mar 7, 2011 | 11:18 PM
what is the srt costing you?
how much labor cost to do the swap?
do u know what wires to cut and wire in the srt?
this is along with the srt harness!
did you see this turn key set up?
there is a lot to it but go for it just have about $15,000.00 for all the stuff u will need,
read the posr #2 three or rour times first.
https://www.crossfireforum.org/forum...es-engine.html
Old Mar 7, 2011 | 11:52 PM
rmaier's Avatar
I will be doing the work on all of this and plan on parking them side by side in my garage and taking all of the SRT6 parts off and replacing the NA parts with all of the things that make an SRT an SRT. I am not sure what all nods are needed in the wiring harness but was hoping for help from you guy's.
Old Mar 8, 2011 | 12:07 AM
downwardspiral's Avatar
Not for nothing, it is cool to have the underdog car with the top end drivetrain.
Old Mar 8, 2011 | 06:41 AM
bluecoupe's Avatar
Is this the low mileage one in OK for sale on E-Bay for $5500? I see it's being parted out....better hurray if it is!
Old Mar 8, 2011 | 08:00 AM
It might be easier, depending on the damage, to use front end parts off of the 2004 and repair the SRT?
Old Mar 8, 2011 | 09:14 AM
rmaier's Avatar
Actually the salvage title and other things make it a better idea to swap the parts to the NA car. Has anyone done this swap before and if so can they give some tips to me so I know the pitfalls?
Old Mar 8, 2011 | 09:28 AM
-----------yes. ---------pm this guy he can help and or he can do it for you. jim
Old Mar 9, 2011 | 10:59 AM
rmaier's Avatar
Can you give me some direction to consider?
Old Mar 9, 2011 | 11:19 AM
pm rudy he can help ,,maybe tell you all the cost ,and what you can and can not do, or he can do it for you ,,as engine swaps into crossfire he has done more than amyone bar none. jim
Old Mar 9, 2011 | 12:08 PM
bluecoupe's Avatar
There was another member a while back swapped out SRT bits into a yellow roadster, haven't heard from them since. Best advise is to contact Ruby......I mean Rudy!
Old Mar 10, 2011 | 12:10 AM
rmaier's Avatar
Default re: swap a srt6 engine and trans in an NA coupe
I have the brakes /rotors, engine, transmission, wiring harness, computers and suspension from the donor car. I will now transfer them to the NA car. Am I going to need to reprogram anything as the wrecked SRT6 deployed the airbags from the accident and the front was damaged. I didn't purchase the seats or dash instrumentation as it looked to be basically the same as my NA car.
Old Mar 10, 2011 | 12:12 AM
rmaier's Avatar
Can I get Rudy's contact info?
Old Mar 11, 2011 | 03:27 PM
rmaier's Avatar
The engine, transmission,brakes and all electrical are costing me $3800
The car had 7191 on the odometer when it was wrecked.
I don't know why I would need the rear end but should I get it anyway?
I haven't seen anything that says it is different from the NA 1 in the car now.
Any other comments before I get started on this project?
I may not have the ability to get other parts from this car after this weekend so please let me know.
Old Mar 11, 2011 | 03:38 PM
rmaier's Avatar
Any comments?
Old Mar 11, 2011 | 05:36 PM
32krazy!'s Avatar
the reason you will need the diff is the gearing that the tcu will recognize. you need to contact rcompart and enlist (meaning pay) him for his expertise in this endeavor. it can be done but its no simple swap. heat exchanger secondary airpump i/c pump ecu tcu just to name a few things that have to considered. being able to decode the ecu which is encrypted in german is why most havent messed with this
Old Mar 11, 2011 | 06:08 PM
rmaier's Avatar
Can you give me his info so I can contact him?
Old Mar 11, 2011 | 06:17 PM
32krazy!'s Avatar
search the member list for rcompart and pm him.
Old Mar 12, 2011 | 09:22 AM
LantanaTX's Avatar
You will need the transmission control unit and it wants to see a 3.07 rear gear which is why you need the diff. check with Rudy and validate this. Did you also get the heat exchanger, intercooler pump, mount and plumbing? Good luck with everything. You will need to work with Rudy to program the ECU to your car.
