NA Autostick jumping gears. Worn?
Old Apr 11, 2011 | 05:20 PM
the.Santorini's Avatar
Default NA Autostick jumping gears. Worn?
I am having this issue where change up selection will skip a gear and change down will work fine. i.e., going from 1 - 3 instead of 1 - 2. I notice if i barely tap it, it will select 2. Othertimes, it might just jump to 4 or D. Anyone else encounter this? Is my shifter getting worn out and needing replacement? Any tips to fix this w/o replacement?
I have 108,555 miles. Most of which involves manual gear selection for enthusiastic tendencies.
Old Apr 20, 2011 | 11:22 PM
jlindsey86's Avatar
Default Re: NA Autostick jumping gears. Worn?
Ever since I have had my car my autostick has been very sensitive when upshifting. It will upshift at the very thought of tapping the stick, however to downshift I have to tap the shifter all the way over to the right. I have just gotten use to this. I assume its just the way Crossfire's are but I could be wrong.
Old Apr 21, 2011 | 06:42 AM
IBLUBYU's Avatar
Checked your Tranny fluid level ??
syfi
Mar 28, 2026 04:14 PM
o55ie18
Oct 5, 2015 05:50 PM
Den656
Sep 23, 2015 12:27 PM
skeet370
29
Sep 18, 2015 05:53 AM
Valk
Sep 17, 2015 11:43 AM
