Any tips for removing rear exhaust hanger/rubbers?
Old May 10, 2011 | 06:27 AM
kolevski's Avatar
Default Any tips for removing rear exhaust hanger/rubbers?
I spent 2 hours today and a whole lot of cursing later trying to remove the rubber hangers holding the rear muffler.
There has to be an easier way to do it for the future? I know alot of you guys have changed your cat backs any tips please?
John.
Old May 10, 2011 | 06:29 AM
maxcichon's Avatar
Default Re: Any tips for removing rear exhaust hanger/rubbers?
John.
Heavy-duty brake spring hook and lots of WD40?
Good luck-they are tough to work with...
Old May 10, 2011 | 07:08 AM
What I found is that the rubber bands are actually stretched somewhat forward to keep the muffler from wobbling side to side. I too had a hard time, the first time. Then I realized that if I take the 3 bolts out of the flange by the cats, it is much easier with the tension removed.
I also cut the centers out of the OEMs before I reinstalled them. Made it easier to install and easier to remove the next time.
This last time I had a new tip put on, I told my muffler guy how the the mounts were pulled forward on the OEM. The new system is solid as a rock with hardly no movement, unlike the Magnaflow system I had on there.
James
Old May 10, 2011 | 08:45 AM
Moparrbust's Avatar
I had to pull the exhaust on a SLK once and I just cut the rubbers and ordered new ones for the install. Very easy.
Old May 10, 2011 | 08:58 AM
Mimi05SRT6's Avatar
Yes, they are one big pain. I attempted it once and went to my buddies shop and he had to use a big crow bar to pry it loose. i
Old May 10, 2011 | 11:58 AM
corfire's Avatar
John.
I used an exhaust hanger removal tool that looked like this:
Exhaust Installation and Removal Tool | AutoZone.com
Also, a cut wire clothes hanger threaded thru the donut helped pull it to the side while I pulled down with the tool. I used a ziptie to hold the two donuts more together when I re-installed. With the Magnaflow, the donut can come loose on one side. The ziptie keeps that from happening.
Old May 10, 2011 | 06:08 PM
kolevski's Avatar
Thank for your replys guys its such a PITA.
I'll try using WD-40 and some sort of hook and hopefully make the job easier. If not I'll just do what mopar did cut and get new ones!
Now I know why there was a nasty mark on my rear end above the exhaust tips after it was at the exhaust shop they must have had a real hard time.
John.
Old May 10, 2011 | 06:12 PM
Lakeview NY's Avatar
I just did mine put some string throught the whole and pulled hard
PNA
Nov 12, 2020 04:44 PM
Jerrysrt6
Jul 24, 2015 09:15 PM
xzmilan
Jul 22, 2015 10:40 AM
rmcdaniel12
Jul 21, 2015 11:35 PM
cjfine
Jul 20, 2015 11:58 PM
