LOSING COOLANT IN SRT6 (any ideas)
Old Jun 8, 2011 | 12:04 PM
RMADERMAN's Avatar
Default LOSING COOLANT IN SRT6 (any ideas)
Interesting, I am losing coolent. It is not leaking on the ground. It is not coming out the exhust. It is not showing up in the oil. But, it is dissapearing. Where tf is it going? The dealer service manager is going to drive it for a few days and measure the loss. They have no clue where it is going. My extended warrenty is with Fedelity as opposed to Chrysler and they will only pay if there is a factual problem.....Ghosts don't count.....The dealer must be able to say this is what is causing the problem. If it were the Chrysler extended Warrenty, they could simply tear the engine down to find or not find the problem without costing me anything other than the $100 deductible.
This coolent loss issue has been going on for a few months.
Any ideas.
Last week the dealer replaced the CPS. They will be replacing the O2 sensor today.
The car had been missing, showing misfire on cylinders 1,3,4. I would pull over, turn the car off and restart the car and it would run fine. The engine light comes on and the pending codes were misfire. That is why the CPS was replaced. I only drove the car for a week when the engine light came back on with the O2 sensor code and coolent light. The car's temperature fluctuates slightly just below too just above the 1/2 way mark.
Old Jun 8, 2011 | 12:28 PM
Kodebuster's Avatar
Default Re: LOSING COOLENT IN SRT6 (any ideas)
When I was losing coolant on my BMW, it was pretty obvious (and quite depressing).
In my case, it turned out to be a cracked Block (aluminum) due to the car overheating once, in very hot weather.
And a blind man could see the issue, as I was blowing white smoke from the exhaust.
When the block was pulled and inspected, it looked perfect to the untrained eye, but upon close inspection with a magnifier, you could see the telltale hairline crack.
I would think if your losing coolant and suspect an engine tear down, you'd see something in the exhaust, or possibly a wet spot somewhere in the engine indicating a coolant leak.
Perhaps a pressure test on the cooling system will turn up something...???
(Just reread your post ~ you indicate the exhaust is clean ~ disregard the Block...lol...)
Old Jun 8, 2011 | 12:30 PM
waldig's Avatar
Talking Re: LOSING COOLENT IN SRT6 (any ideas)
INTERCOOLER>. WOODY
on the intake side. Pressure test it is easy, pop off hoses and prime it and then watch gauge.
Old Jun 8, 2011 | 12:38 PM
yes, I believe Woody is on to something...it's under the s/c Randy...not something you will want to do.. Rob had a thread about fixing his awhile back...
Old Jun 8, 2011 | 01:06 PM
NeedsWings's Avatar
i agree, id bet you have a leaking intercooler, you can pull off one of the intake manifolds and look inside it. if the IC is leaking you will see the fluid there. in every case we have seen yet the intercooler has been not repairable and required a new intercooler (dealer wants about a grand for a new one).
Old Jun 8, 2011 | 02:08 PM
velociabstract's Avatar
Default Re: LOSING COOLANT IN SRT6 (any ideas)
My intercooler has a slight leak and most of the goop ends up in the passenger side manifold. If your going to pull one I suggest the passenger side. I don't know if the plugs would show signs of the coolant or not. When I pulled my plugs I couldn't see anything abnormal.
Les
Old Jun 8, 2011 | 02:33 PM
BLACKSRT-6's Avatar
I have the same exact issues and have been working with my dealer for 2 months to get it corrected, luckily it's still coverred. If it is an intercooler, it will not show in the standard Chysler collant system pressure check, thier collant dye checks or coolant exhaust gas checks.
The car will need a intercooler pressure test for leaks or you can pull the intake manifold and look for the stains. The plugs do not show discoloration unless you have a head gasket leak as the coolant is being too evenly distributed to the cylinders with a minor intercooler leak.
My O2 sensor also failed and the car was showing cylinder misfire codes, I think this is a common early onset of the coolant being burned, the O2 sensor failing will show on different cylinders at different times.
Are you using a dealer to get it fixed? If so I think we should get them both talking to save you some time and trouble.
I'll send you a PM with my number.
Old Jun 8, 2011 | 03:15 PM
tighed1's Avatar
+1 Intercooler.
Coolant is rejecting your BLACK car. Trying to get away!
Old Jun 8, 2011 | 03:19 PM
I quess we will have to paint them yellow.....then...or Hugger Orange....I'm thinking Orange with a lot of "FP" chrome....
Old Jun 8, 2011 | 03:32 PM
BLACKSRT-6's Avatar
Originally Posted by tighed1
+1 Intercooler.
Actually, it's the gray roadster that I picked up from a member on the forum. Been leaking since I got it. So much for all the "what a great guys" that were posted on his sale.
Old Jun 8, 2011 | 06:44 PM
He is a great guy....never stated once his car was....had been run hard and put up wet many times....I know I was right beside it...sometimes, more so than not, just slightly behind it....made a few mods since those times....lol....It is a proven ride though....we will all have to fix this problem down the road it sounds like...
The car was on you tube, and was on a few "burn out" photos...right here on the forum....that should have given you a little knowledge of the car's history...Mine sees the track once in a great while, the roadster that is, and the coupe has yet to make it's debut. As long as you service them, treat them right, replace what you break, the cars that see the track and are parked in the garage the rest of the time, are quite ready when needed. Mine gets the best of everything. Of course, they aren't for sale either...but when the time comes, most know the cars already....from this forum...and the get togethers...
Old Jun 8, 2011 | 06:52 PM
Randy i told you a while back that Rob had the same problem and that it was your intercooler,,not the heat exchanger,,, sorry man i just hope the warranty takes care of it, and with you it will jim
Old Jun 8, 2011 | 07:16 PM
Well I'll be the first to say it, I think 50% have this problem to some extent and 99% don't know it. My car runs great and the only reason I know is because I took my manifolds off to put on the Needswing's teflon coated Y pipe and saw the goo. I'll be looking for a replacement in a relaxed fashion .... if it gets worse or I find a bargain.
Les
Old Jun 8, 2011 | 07:42 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Originally Posted by waldig
INTERCOOLER>. WOODY
What pressure is safe for testing purposes?
Old Jun 8, 2011 | 10:48 PM
RMADERMAN's Avatar
I spoke with my service rep and he is inclined to agree that the Intercooler is the issue. It is now up to him/them to figure out how to convince Fedelity that replacing the intercooler is the cause of the problem. Taking off the manifold might show them a visual and they will agree to replace it.
Jim, Where is your SRT??????. Is it on its way to FLL yet? I got to see mine today. LOL Visitation rights I still have. I even touched it.
Old Jun 9, 2011 | 10:47 AM
BLACKSRT-6's Avatar
I had no problem with the car being run hard, I do the same (street, track, autocross and 1/4). I'm on my 3rd set of rear tires in 30,000 miles and I have drag radials and A6's mounted on extra rims.
The seller did discuss a coolant leak on the forum and had it in the shop to be checked but went back and changed/deleated the posts, he also included three gallons of collant in the trunk with the other spare parts that went with the sale?
The price was right, no issues I can't or haven't fixed and it came with gold coverage. The point is, just because someone is nice or fun to be around does not make them trustworthy.
Old Jul 21, 2011 | 04:19 PM
BLACKSRT-6's Avatar
Update on my coolent leak. Dealership says the replacement intercooler is on back-order. Appearently there is somewhat of a demmand on intercoolers for this engine. The estimate is 1 week to get the car back.
Old Jul 21, 2011 | 04:48 PM
RMADERMAN's Avatar
Yes, as a matter of fact, I just got my car back yesterday after almost a month. The intercooler was replaced and it looked like avocado dip when they removed the supercharger and intercooler. It was a ***** getting the IC as it was on backorder, The dealer wanted to replace the supercharger, but Fedelity said no. I think the dealer charged around 3k to the aftermarket waranty company.
Now they want to change the Cats under Chrysler emisions waranty.
ps I had to put my butt on the line for $850 and ok the tear down to find the problem. Thanks to the Crossfire forum members I felt comfortable with the diagnosis.
Old Jul 21, 2011 | 05:35 PM
glad you have her back Randy.....hopefully she will be good to you for many more years..
Old Jul 21, 2011 | 07:05 PM
BLACKSRT-6's Avatar
Are the cats a result of the intercooler leak? What indications was there for the cats to need replaced? Thanks
