popping noise from exhaust
Old Sep 4, 2011 | 05:21 AM
essex.dave's Avatar
Exclamation popping noise from exhaust
basically i have a 2004 chysler crossfire, and recently whenever i start the car first thing in the morning there is a popping noise noise coming from the exhaust it stops making the noise as soon as the engine warms up wondered if anyone could help me please.
Old Sep 4, 2011 | 06:33 AM
Default Re: popping noise from exhaust
You miqht have an exhaust leak.
Old Sep 4, 2011 | 06:40 AM
May just be moisture in the exhaust...not uncommon to have a popping sound thru the exhaust
Old Sep 4, 2011 | 06:57 AM
waldig's Avatar
Talking Re: popping noise from exhaust
You may be rich and causing backfire in exhaust system, is there any signs of richness in the exhaust, smell???Woody Unburned fuel....
Old Sep 4, 2011 | 06:58 AM
essex.dave's Avatar
so what should i do, is it nothing serious then if it is just moisture in the exhaust.
and dont think there is any unburned fuel, theres no smell.
Old Sep 4, 2011 | 07:02 AM
Well, Woody had a good point as well...these cars do tend to run rich at first, so whether moisture, or fuel...this is a normal thing, and I wouldn't worry about it...especially since she is fine once warm...both indicating it isnt' a problem...drive it and enjoy...welcome btw..
Old Sep 4, 2011 | 07:06 AM
essex.dave's Avatar
thank you everyone was just a little worried because it has only just started doing it.
but i may just check the exhaust for leaks to be on the safe side
Old Sep 4, 2011 | 07:08 AM
Dave, if the exhaust is leaking, it will pop all the time, not just when cold...good luck...
Old Sep 4, 2011 | 07:13 AM
essex.dave's Avatar
oh ok thanks oledoc2 you have been very helpful, the popping only happens when i start the car when the engine is cold so guessing there no leak then as it stops popping when she warmed up after a min.
Old Sep 4, 2011 | 07:15 AM
expansion and contraction Dave...if there is a leak, it is small enough to close once warm... all things mentioned are possible, but nothing to worry about...
Old Sep 4, 2011 | 09:40 AM
Kodebuster's Avatar
The only thing that would bother me about a (possible) exhaust leak, even if it was very minor, and stopped on warm (due to expansion), was the possibility of fumes seaping into the car.
Although if this was the case, you should notice if it had entered your interior (with that unique smell).
Couldn't hurt to jack it up, or put on a lift and check around (especially for corrosion at any joints)...
Old Sep 4, 2011 | 10:18 AM
essex.dave's Avatar
yeah thanks kudobuster i will check but like i say i cant smell anything at all but doesnt hurt to check i guess.
ty_ty37
Jun 27, 2024 10:42 AM
TerryR
Dec 13, 2019 03:27 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
