P0172 & P0175
Old Feb 13, 2012 | 12:55 PM
rtaylor977's Avatar
Default P0172 & P0175
Hi, I have two codes coming up P0172 &P0175. I went to change the MAF sensor and the viehicle would not idle when replaced. I thought it must be a bad MAF, but when I put another one on I gat the same reaction. Could someone have re-programmed the computer that would cause this? Any other ideas?
Thanks
Old Jun 30, 2019 | 10:41 AM
Xfire005's Avatar
Default Re: P0172 & P0175
Did you ever find out the problem 🤔
Old Jun 30, 2019 | 07:51 PM
He posted that 7 1/2 years ago and never posted again.
Old Jun 30, 2019 | 08:20 PM
Xfire005's Avatar
I just seen the date 😂
Old Feb 3, 2020 | 05:30 PM
bc75's Avatar
Anyone figure it out im getting the same codes. When i get a chance im going to clean the throttle body and mass air flow sensor. See if that helps. Im only getting the code when i drive my car hard.
Old Feb 3, 2020 | 08:37 PM
zip439's Avatar
There are quite a number of things that can cause those codes. Cleaning the MAF will do no harm, but I wouldn't start replacing parts hoping for a cure. First get the car scanned properly with a quality Mercedes or DRB III tool. If you haven't access to something other than a generic OBD II scanner it would be best to take the car to an independent garage that specializes in European imports and let them scan it. A good scan should get you headed in the right direction; MAP sensor, throttle position sensor, thermostat, air or coolant sensors, several different possibilities in the exhaust system. Get it scanned.
Old Feb 3, 2020 | 09:36 PM
bc75's Avatar
I will get it scanned. I got on it hard coming home from work at a dead stop i got p0175 p0172 plus multiple cylinder misfires. Shut the car off then started right back up ran normal.
Old Feb 6, 2020 | 09:38 PM
bc75's Avatar
I cleaned my mass air flow sensor and throttle body today. It runs like new again.
Old Feb 7, 2020 | 07:54 AM
zip439's Avatar
Great News; Really glade that has worked for you. Thanks for posting the solution. Enjoy the ride!
texasboy_11b
Oct 13, 2022 08:05 PM
Crossfire4572
Aug 4, 2013 11:27 PM
bluetb
Jun 27, 2013 11:18 PM
HDDP
Jun 2, 2007 11:57 PM
