Funny thing happened while changing oil
Old Mar 11, 2012 | 10:47 AM
cgs0409's Avatar
Default Funny thing happened while changing oil
It was about time for the 2nd oil change since buying the car. It had 13,000 miles when I bought it and the owner told me it was time for an oil change. So, I bought a vacuum transfer tank with a hand pump...hated it...took forever to drain the oil out of the sump. So I looked around and found a 12V oil change pump at Academy Sporting goods in the boat motor section. Got it home hooked it up to the battery...stuck the tube in the dipstick tube and the other tube in a 5 gallon catch can. Hit the on switch and the oil started flowing up the tube to the pump then to the catch can. I noticed the discharge line was vibrating quite a bit so I stuffed a rag to hold the tube in the catch can. I turned around and the discharge came flying out of the can and oil was going everywhere. I hate it didn't get caught on camera as it took several seconds to get it back in the can. Needless to say the car, concrete patio, and I had oil all over us. The pump worked great...maybe too good. For less than $25 the pump was a good buy. Just be sure to secure the discharge hose!!!
Old Mar 11, 2012 | 10:59 AM
Default Re: Funny thing happened while changing oil
................it happens to a lot of us who do our own thing...I still change mine the old fashion way...but, I have tripped with the drain pan on my way to dump it into the barrel I had for used oil....nothing like power washing the driveway after an oil change...lol...
Old Mar 11, 2012 | 11:15 AM
arado's Avatar
everything becomes obsolete. I was given a pneumatic oil extractor when I bought my SRT6 coupe. I tried it and now use it exclusively on my cars, bikes and lawnmowers. I get the oil out with no spillage. FAST!! gary
Old Mar 11, 2012 | 07:23 PM
waldig's Avatar
Talking Re: Funny thing happened while changing oil
Me, I like to drain the oil from the bottom when its hot to get it all out and check the magnetic drain plug. I even do the oil filter first to break the suction and get it all out. Magnetic plugs allow you to get an idea of bad things that might be going on. ENJOY, Woody
Old Mar 12, 2012 | 01:50 PM
Kodebuster's Avatar
Originally Posted by cgs0409
So I looked around and found a 12V oil change pump at Academy Sporting goods in the boat motor section. Got it home hooked it up to the battery...stuck the tube in the dipstick tube and the other tube in a 5 gallon catch can...
If you can post a model number and brand name on this unit, it's appreciated.
I'm interested in getting one, and maybe I can find it online, rather than a trip to a boat store...
Thanx...
Old Mar 12, 2012 | 03:11 PM
tom2112's Avatar
She can ride with me ;)
My "favorite" oil change screw-up is forgetting to put the plug back in before adding the new oil.
I just love pouring $30 worth of oil down the drain.
Old Mar 12, 2012 | 04:34 PM
Thought I'd go cheap on the Cub Cadet RZT Kawasaki 22 HP last year on the oil change and got a filter from NAPA that looked right. Got done, cranker 'er up and immediately blew the filter off and oil all over the place. Turns out the threads weren't quite the same.
Old Mar 12, 2012 | 05:37 PM
cgs0409's Avatar
Thanx...
The name of the pump was Smiths...not sure of the model number. There are several online offered by boating supply company's. All are in the $25 range. Do a search for 12V oil change pump and that should get you close. Buying at Academy was cheaper when figuring in shipping.
PNA
Nov 12, 2020 04:44 PM
xfClifford
Aug 3, 2015 11:03 PM
Crossfireconv08
Jul 30, 2015 12:11 PM
Jul 29, 2015 06:13 PM
skeet370
Jul 18, 2015 01:02 PM
