what is the best replacement for rear subs??
Old Apr 8, 2012 | 10:58 AM
hemibeep's Avatar
Question what is the best replacement for rear subs??
What will fit and work to replace blown rear subs? the foam surroud is falling apart.
Brand and model number if possible.
thanks
Old Apr 10, 2012 | 07:50 PM
Choppy's Avatar
Default Re: what is the best replacement for rear subs??
-Boss BP6.8 - No modification - direct fit
-Lanzar VW64 - No modification - direct fit
-Pyramid WX65X - No modification - direct fit
-MTX Audio RTX658 - No modification - direct fit
-Boss Audio NP6.4 - No modification - direct fit
-Earthquake Sound SWS-6.5X - No modification - direct fit
-Crossfire XS M6 6" XS - No modification - direct fit
-Kicker CVT654 - No modification - direct fit
-Tang Band W6 - modification and cutting required
-Ultra series LV 6 - modification and cutting required
-JL Audio 6W3v3-4 - - modification and cutting required
-DD Audio SW6.5 - modification and cutting required
-RE Audio XXX6.5C - modification and cutting required
-Peerless SLS 6.5 - modification and cutting required
-CDT Audio CL-6MSUB - modification and cutting required
-CDT Audio M6+ - modification and cutting required
Best overall sounding in no particular order & requires modification and cutting.
-DLS Reference RW6
-CDT Audio ES-06
-Focal Utopia Be 5" (13ws)
-JL Audio 6W3v3-4
-JL Audio C5-650cw
-Rainbow Vanadium 7"
Old May 28, 2012 | 09:27 PM
smokey847's Avatar
I'm interested in installing a pair of JL W3s. Could you enlighten me or direct me to a post that explains the modifications required? Thanks.
Old May 28, 2012 | 09:38 PM
Choppy's Avatar
Mine might be up for sale within the next week or so. Last night car was involved in major front end crash 3 airbags deployd. Waiting to hear from insurance company to see if totaled if so they are up for sale. Will include 2 - 10 w3's and custom fiberglass encloses.
Old May 29, 2012 | 08:59 AM
smokey847's Avatar
Choppy, if you could, please upload a picture of the box at your earliest convenience. Thanks.
Old May 29, 2012 | 07:29 PM
Choppy's Avatar
https://www.crossfireforum.org/forum...***-boxes.html
Old Aug 27, 2012 | 09:21 AM
JesseJamessrt6's Avatar
-DLS Reference RW6
-CDT Audio ES-06
-JL Audio 6W3v3-4
-JL Audio C5-650cw
Excellent list, thanks for the info!
Old Aug 31, 2012 | 08:53 AM
-DLS Reference RW6
-CDT Audio ES-06
-JL Audio 6W3v3-4
-JL Audio C5-650cw
Installed the Kicker CVT654 last night. It is a single voice coil, not a dual like the factory sub and there IS modification required to the two piece plastic basket housing and slightly to the sheet metal in one small area.
Old Sep 6, 2012 | 02:26 PM
solnyc2's Avatar
@ JesseJamessrt6
-DLS Reference RW6
-CDT Audio ES-06
-JL Audio 6W3v3-4
-JL Audio C5-650cw
How do they sound? do you get great bass response?
I have a Kenwood exelon system and aftermarket amp. The only thing that is stock are the rear speakers.
I blew one OEM rear speaker so I am considering these.
Thanks!
Old Sep 11, 2012 | 09:03 PM
there is literally no bass because the oem amp is wired to push the dual voice coils which drops the ohm load to give more punch. After market subs in 6.5" size are not dual voice coil so there is no way to drop the ohms as in an oem setup (unless you bridge the oem amp but I read that it is not able to handle being bridged) so the aftermarket subs are under powered.
I am waiting to get an aftermarket amp now.
Old Jan 19, 2013 | 07:13 PM
lildaddym's Avatar
Anyone have the specs on the OEM speakers? Depth, impedance, power rating?
Old May 20, 2013 | 09:34 PM
lildaddym's Avatar
MrMiata brought up that none of the direct fit subs in the list are dual voice coil...here are some that MAY work, no guarantees:
Pyle PLPW6D
Audiopipe 6.5
CDT Audio HD-6MDVC
Bazooka WF641.5DV
Old Jul 1, 2013 | 12:13 AM
Selbyl's Avatar
Pyle PLPW6D
Audiopipe 6.5
CDT Audio HD-6MDVC
Bazooka WF641.5DV
Is it possible to have a sticky of speakers that are confirmed to fit behind the seats?
Old Jul 1, 2013 | 12:29 AM
lildaddym's Avatar
+1 on the sitcky...good reference material!
Old Jul 1, 2013 | 12:53 AM
tageier's Avatar
Did you ever put new ones in? I still don't see any conclusive speaker that will fit without modification that sounds good??
Old Jul 1, 2013 | 01:08 AM
lildaddym's Avatar
I repaired the one I had that was problematic...
Old Aug 16, 2013 | 10:19 AM
jimmirehman's Avatar
Default
Has anyone found a no modification direct fit dual voice coil? I need to replace the rears but want some kind of base.
-DLS Reference RW6
-CDT Audio ES-06
-JL Audio 6W3v3-4
-JL Audio C5-650cw
Old Feb 3, 2014 | 08:53 PM
maxcichon's Avatar
Pyle PLPW6D
Audiopipe 6.5
CDT Audio HD-6MDVC
Bazooka WF641.5DV
Amazon.com: Pyle PLPW6D 6-Inch 600 Watt Dual 4 Ohm Subwoofer: Car Electronics Amazon.com: Pyle PLPW6D 6-Inch 600 Watt Dual 4 Ohm Subwoofer: Car Electronics
This works and has decent bump from the OEM amp.
Dremel work required.
I'm installing a new Kenwood power amp for the subs and replacing my HU.
Old Feb 4, 2014 | 12:40 PM
arejohn's Avatar
I caught the price of $18 and immediately thought that covered shipping. Can we really get a better than OEM woofer for that price?
Old Feb 4, 2014 | 08:09 PM
maxcichon's Avatar
Having both units on my bench at the same time, and evaluating the quality of manufacture, The $18 you scoff at is NOT warranted. The OEM sub is a real POS. Mine were just fine and I sold them on for...too little. He wanted to keep his xF pure. Good for him.
These are tighter, louder (more efficient) and better-built.
Ball is in your court...
