Left headlight burnt out!!
Old Apr 9, 2012 | 11:49 PM
freshsurf's Avatar
Default Left headlight burnt out!!
Hey everyone,
I have a 2004 crossfire up here in calgary canada and my left headlight is burnt out, when I put in a new bulb there is no flicker nothing. Is it my relay switch? need some help with this one..
all the other lights are working fine!! flogs and all!!
Old Apr 10, 2012 | 05:12 AM
Mrmiata's Avatar
Default Re: Left headlight burnt out!!
Originally Posted by freshsurf
Hey everyone,
Check your fuses.. If I recall correctly they are independantly fused.
Old Apr 10, 2012 | 11:43 AM
freshsurf's Avatar
I checked the fuses this morning once again and found nothing that indicated anything to do with head lights. That being said is there another location other then the drivers side under the hood?
thx
Robert Woolner
Old Apr 10, 2012 | 11:54 AM
Mrmiata's Avatar
Does the high beam work on that side? If it works check fuse #8 in fuse box that's on the side of the driver side dash panel. It should be a blue 15 amp fuse.
from searching "HEADLIGHT FUSE".. I'm sure you can find more, and I'm not positive this would be the only fuse...
Old Apr 11, 2012 | 11:24 PM
freshsurf's Avatar
So I found the panal but the fuse was still good. Looks like something more serious any ideas?
Old Apr 11, 2012 | 11:45 PM
Please check the fuses next to the one you checked. I once mistakened a fuze for one next to it because the numbers were confusing.
Old Apr 13, 2012 | 12:43 AM
freshsurf's Avatar
I just check over 4 times and not one fuse was out! This is becoming a serious issue!! any more ideas to try out?
Old Apr 13, 2012 | 01:44 AM
robby363's Avatar
Have you tried more than one new bulb? Maybe you got a bad new bulb.
Old Apr 13, 2012 | 02:31 AM
You say left headlight is that high or low beam, we take left to be the driver side - fuse 8 low beam, fuse 5 high beam. Passenger side, fuse 6 low beam, fuse 3 high beam.
You were asked if the high beam worked but you gave no answer. Answering questions helps diagnose problems, ignoring what may seem a stupid irrelevant question does not help.
The fuse is OK you say but is there any power going to the socket? That is the first step to take, you work back from there, check the fuse in the other side headlight. Sometimes fuses look OK but are faulty in some way.
Old Apr 13, 2012 | 12:22 PM
freshsurf's Avatar
So it turned out to be just a bad bulb!!! Lol thx for your help I am back on the road all lit up!!!!!
Valk
Jun 22, 2025 09:15 PM
Franc Rauscher
May 9, 2016 12:04 PM
gibsonjunkie
Sep 22, 2015 01:58 PM
tritongreen
Sep 18, 2015 07:32 AM
RacerXofFL
Sep 15, 2015 05:00 PM
