vibrating shifter above 75mph
Old Jul 24, 2012 | 09:18 AM
xviiviexie's Avatar
Talking vibrating shifter above 75mph
Hi! (2004 ltd coupe,117k)
Let me start out by saying this forum has kept my car up and running without being exploited by dealerships. Lately i have noticed that at speeds above 75mph my gearshift tends to vibrate. past 80mph it vibrates rather violently, but i cant really keep an eye on it cause im driving at speeds of 80mph.
I bought engine and trans. mount/s, but have yet to replace them. i have been reading up on the subject and i have heard "gearshift bushing" mentioned in regards to vibrating shifter. also some people are saying flex disc/guibo.
i dont know if its worth mentioning but when putting her in park there is always a metal click/popping sound. also,there are spots on the airbox where it is rubbing up on the insulated hood liner on the uppermost outer back corners of the box.
should i jump to conclusions and replace the mounts for both engine and trans. along with the gearshift bushing? or do you think the vibrating shifter is a driveshaft issue? the higher speed the more violent the shake. needless to say im going 70 on the dot. HELP?
if i dont get a reply soon i think i will jump the gun and have the shop do the mounts.
Old Jul 24, 2012 | 10:32 AM
JHM2K's Avatar
Default Re: vibrating shifter above 75mph
The engine mounts on these are notorious for failure.
Two things that lead me to believe it's the engine mounts:
  • Abrasions on the airbox (from the engine flexing too far)
  • Vibration in shifter increases as speed (RPM) increases
In this one case, it's almost worth it for anyone to have a shop do the repair, as the swap is a nightmare and nearly impossible to torque to specs.
LE Cross
Oct 17, 2016 06:35 AM
mobilefitt
Nov 8, 2015 08:30 AM
Selbyl
Sep 22, 2015 09:31 PM
Big Daddy
Sep 10, 2015 10:21 PM
chturner
Aug 23, 2015 06:14 PM
