engine cover...
Old Aug 5, 2012 | 01:03 PM
sgthied's Avatar
Cool engine cover...
Help, I need guidance on removing the engine cover. I don't want to break it and was hoping for guidence on the removal of the cover. Thank you
Old Aug 5, 2012 | 01:16 PM
Angelospinner's Avatar
Default Re: engine cover...
Remove the intake tubes, then give a good pull at each corner. It is just held in place by 4 pressure clips.
Old Aug 5, 2012 | 01:18 PM
RL67037's Avatar
It just pops off. I think there are 4 clips that hold it on. Just pull up on it and you'll feel it pop loose - work your way around until it is comes off. Pretty simple.
RL
Old Aug 5, 2012 | 01:29 PM
Give it a sharp upward tug at the rear, that is the place to start on the NA. Which I assume it is.
Old Aug 5, 2012 | 02:12 PM
Be careful at the passenger side front - it is easy to crack the cover if you tug too hard there ......
Old Aug 5, 2012 | 02:35 PM
sgthied's Avatar
Thanks for the replies. It was easy I'm just so afraid of breaking something. The filters were clean so no worries there.
Old Aug 13, 2013 | 04:17 PM
Alabaster xfire's Avatar
So i've been reading alot of threads about how to remove the engine cover. I'm wanting to remove mine so I can paint it, but people keep giving two different steps. 1.) remove the intakes then pull on the cover to pop the 4 clips. 2.) pull on the cover to pop the four clips. Before I attempt this I just want to know... do you really have to remove the intakes?
Old Aug 13, 2013 | 04:22 PM
RL67037's Avatar
Default
Intake removal is NOT required. Just gently pry up on it and it will pop loose.
janaiy
53
Nov 2, 2015 09:23 PM
RacerXofFL
Sep 15, 2015 05:00 PM
BEATv1
Sep 10, 2015 12:58 PM
RiderJC
Sep 7, 2015 11:19 PM
MickeyNasty
Sep 6, 2015 08:29 PM
