What do I need ... Looking to return to OEM intake, from NEEDSWINGS
Old Sep 1, 2012 | 05:26 PM
IBLUBYU's Avatar
Default What do I need ... Looking to return to OEM intake, from NEEDSWINGS
When I bought my SRT, it came with a single Needswing CAI, installed by the previous owner. I'd like to re-install an OEM intake set-up (which I have). I have none of the parts or brackets that were removed from the car, when the NW CAI was installed. I know I need the passenger side, plastic radiator pass-thru piece, but not sure about anything else. Hoses? brackets? What say ye guru's of knowledge?
If any one has these pieces collecting dust, let me know ,,,,,,,,
Old Sep 1, 2012 | 05:47 PM
robby363's Avatar
Default Re: What do I need ... Looking to return to OEM intake, from NEEDSWINGS
If you still have the oem set up you should be all set other than the piece you need that goes between the radiator. Do you have the hose that goes on the oem intake?. You can find the install pdf. file here in post#2 that shows the hose I'm talking about and any other parts you might need.https://www.crossfireforum.org/forum...tructions.html
Old Sep 1, 2012 | 06:00 PM
MoparFreak69's Avatar
Plans on selling the NW intake? Will it fit an NA?
Sorry I cant be of help here.
Old Sep 1, 2012 | 06:29 PM
IBLUBYU's Avatar
No and no ........
Old Sep 1, 2012 | 06:39 PM
FUBU's Avatar
Need some extra OEM parts let me know.
Old Sep 1, 2012 | 07:05 PM
IBLUBYU's Avatar
Originally Posted by robby363
If you still have the oem set up you should be all set other than the piece you need that goes between the radiator. Do you have the hose that goes on the oem intake?. l
Robby .... Thanx for the linky to the install. That helps..... As mentioned, what ever was changed/removed during the install by the prev owner, I don't have!!!! I have an OEM intake set-up that I picked up at some point, but it didn't come with the original intake breather hose, OR the plastic radiator pass-thru piece. It also looks like I may need a couple of remount brackets(maybe) for the horn and the shorter bracket/clamp for the radiator cooling line.
Old Sep 1, 2012 | 07:28 PM
FUBU's Avatar
I have all parts of the oem intake fot the srt6.
Dec 2, 2015 12:49 AM
Mrmiata
Sep 22, 2015 05:18 PM
Ralph289
Sep 21, 2015 09:34 PM
Valk
Sep 17, 2015 11:43 AM
RacerXofFL
Sep 15, 2015 05:00 PM
