Stereo Help
Old Oct 15, 2012 | 05:35 PM
bwatral44's Avatar
Default Stereo Help
Hello all, Ive installed stereos before but the crossfire has me baffled, I recently bought the jensen UV10 and had it all wired up and had all the color going to the corresponding colors. Heres the thing everything worked the unit lit up, the 7 inch touch screen went up and down but absolutely no music was played. everything worked but no music. ive seen alot about wiring to the factory amp but was curious if someone could verify a little more.
ps ive already looked at the sticky for ""installing the aftermarket radio"" but still seems like im unable to figure it out.
any help is appreciated!!!!
Old Oct 15, 2012 | 06:07 PM
stryfox's Avatar
Default Re: Stereo Help
Some radios you need to set the aux wire.
Usually blue or blue with a stipe for a power ant air external amp.
I had this problem with a pioneer avic z1
You had to go into the menus an set it to turn on all the time.
This might help. Without being there with a meeter it is difficult to say
Old Oct 15, 2012 | 06:24 PM
bwatral44's Avatar
would it matter if i still didnt have the radio attena adapter i put the factory radio in without it and it still worked?
Old Oct 15, 2012 | 07:12 PM
Mrmiata's Avatar
Isn't there a red to yellow swap in there?
Old Oct 16, 2012 | 09:02 AM
closer9's Avatar
Red to yellow swap will only affect the internal memory - battery vs accessory power. Most likely you don't have a power wire (blue wire stryfox mentioned) hooked up for the amp.
Old Oct 16, 2012 | 09:28 AM
Mrmiata's Avatar
Just thought I'd save him another WTF when it didn't store his settings.. since he noted wired up "color to color"
Old Oct 16, 2012 | 12:05 PM
closer9's Avatar
Gotcha... Interestingly, I've seen this mentioned several places, but didn't have that issue with mine.
deerhunter
Jan 16, 2021 10:56 AM
Wisconsinfdcrossfire
Sep 20, 2015 10:04 PM
spoiler
Aug 30, 2015 03:17 PM
x1xsinisterx1x
Aug 24, 2015 07:31 PM
Sussudio
Jul 3, 2015 10:56 PM
