ECU cooling fan
Old Nov 2, 2012 | 11:43 AM
hpmotors's Avatar
Default ECU cooling fan
I've had a sound I hear inside the car that has been increasing in intensity over time. Tracking it down, it seems to be coming from the underhood box the ecu is in. I've read that there is a cooling fan in this thing that pulls air out of the passenger compartment to cool the ecu. Noise is just like a PC with a bad cooling fan. Anyone else had this issue?
Chrysler says the fan comes as part of the box - not available separately. Wanted to see what the options were before I took this thing apart.
Old Nov 2, 2012 | 12:06 PM
tunaglove's Avatar
Default Re: ECU cooling fan
Yup, mine howls like crazy for a few minutes when it gets cold out. Fine in the summer. It's under the RCM and ECU and looks like a pain to get at.
Old Nov 2, 2012 | 01:50 PM
bigblock427's Avatar
Hello,
if Chrysler won't sell the fan seperately, you can get the fan from a Mercedes-Benz dealer, or anywhere else.
MB OEM part number is: A 170 545 00 95
Regards
Markus
Old Nov 2, 2012 | 03:39 PM
MrMoPar's Avatar
I have five, but have to figure out how attached to the plastic vent tube to get them off.
Old Nov 2, 2012 | 04:21 PM
maxcichon's Avatar
There are a number of threads on MBworld and others on this. There are a number of OEM 12VDC fans to fit. If you can get to yours, write down the number and do a Google search on it. From what I've read, this fails often and the Japanese replacements are longer-lived and much cheaper (~$20).
BTW- I think this fan also cools the stereo amp in the passenger floorboard. It will fail too if the fan goes...just sayin'.
Old Nov 5, 2012 | 08:31 AM
hpmotors's Avatar
Great info guys - thanks for the part numbers. Now I have to get my tail in gear and pull the thing. Replacing just the fan motor is a whole lot better than the ~$165 the dealer wanted for the entire enclosure.
Old Nov 5, 2012 | 08:34 AM
hpmotors's Avatar
With you on that. I didn't mind the screeching so much - it was when it quit making noise that I wondered did it just quiet down or quit running
syfi
Mar 28, 2026 04:14 PM
Valk
Jul 12, 2021 09:49 PM
Oct 1, 2015 01:42 AM
ozkancab
Sep 25, 2015 10:55 AM
waldig
Sep 17, 2015 10:35 AM
