Infinity 609CS Tweeters
Old Nov 11, 2012 | 07:16 PM
gp1200x's Avatar
Default Infinity 609CS Tweeters
Anyone install this two way component speaker system in the factory door locations? It is as low as $129 and the ratings are very high. It's two ohm and I plan on using the factory amp with a new HU using RCA preamps (4V+) with the fronts and sub woofers on separate channels.
I see a lot of comments on other car forums about the tweeters not fitting their factory holes / depth concerns and I am wondering if this will be a problem with the Crossfire doors.
Thanks
Old Nov 11, 2012 | 11:21 PM
Indelibility's Avatar
Default Re: Infinity 609CS Tweeters
I picked up a set of Polk DXi6500 components. The midrange fit perfectly, though getting the factory speaker out was a pain at first. As for the tweeter, I removed the factory one, used a Dremel tool to cut out a larger opening on the inside, used clear silicone to hold the new tweeter in place (acts as insulation in my book) and spliced the wires. The first door took me almost 3 hours, but once I figured it out I had the second door done in 20 minutes. If you need any pointers feel free to PM me.
This is the finished product, I have a Base model BTW...and it sounds fantastic with my Pioneer HU!
usprb1976
Apr 4, 2024 04:57 PM
rocketrage
Oct 7, 2015 05:00 PM
LE Cross
Sep 14, 2015 01:20 PM
brhertel
Jan 5, 2007 02:09 AM
Eracer76
Jul 18, 2006 11:37 PM
