c350 intake tubes???
Old Nov 14, 2012 | 07:37 PM
GTR DRAGON's Avatar
Default c350 intake tubes???
Has anybody tried to use the the intake tubes/ hoses from the 2007 c350? The M112 owners on the Mbenz forums swear by them, however I've only seen them used on c320 sedans/ coupes. So my question is will they fit on crossfire/slk platform? (basically making it to or through the radiator support)
Old Nov 14, 2012 | 08:23 PM
Indelibility's Avatar
Default Re: c350 intake tubes???
Got any pics or a thread link? This sounds interesting.
Old Nov 15, 2012 | 12:36 AM
GTR DRAGON's Avatar
Here is one of the links
DONE: Kevlar Intake tubes for M112 Motors. - MBWorld.org Forums
Old Nov 15, 2012 | 07:13 AM
I guess that could work, but wouldn't using intake heat wrap be far more effective since it would cover the entire tube? Not to mention it would conform to the tube, not just lay on it.
Old Nov 26, 2012 | 06:53 AM
GTR DRAGON's Avatar
I think the tubes have a larger diameter then the stock intake tubes. They may be even larger then the c320/v8 air-boxes intake tubes too.
Random off shoot- question which is the better air box the v8 or c320 air box. or are they both the same (I know the slk one is exactly the same as the crossfire)
Old Nov 26, 2012 | 09:29 AM
Strangely, this has all been covered before and a simple look through the old threads will give you a lot of info. There is only one air box that fits to my knowledge and some of the air boxes that look correct are just a little too high and rub on the hood liner and leave a dent in it. The V8 air boxes do not fit because of this, they clip in place no trouble but are too high by about a 1/4" or so.
The NA OEM intake pipes will fit inside the correct air box intakes until you can get the proper ones. When I did this mod on my NA I made adapters to extend the length of the new intake tubes to get more of the intakes through the radiator support but I did not use them in the end.
I will add the thread that covers this, it lists all the part numbers for the Mercedes parts from the throttle body to the intake tubes.
List of parts.
By coincidence I took two air boxes that were the wrong part number to the dump on Saturday, one I made a mistake in buying and the other was shipped in error when I ordered the correct number, it was replaced by the seller who told me to keep the wrong part. He also sent me a V8 nose piece, brand new, and it now resides in the dump as well.
I took some screws, clips and donuts off these parts, maybe I'll need them one day, but I doubt it.
The link in my signature lists many of the threads covering common problems, fixes and mods. The thread I am referring to is listed there as well.
Old Nov 27, 2012 | 07:30 PM
GTR DRAGON's Avatar
I wish you would have saved the nose piece , I like the black v8 nose piece, better than v6 silver striped one shoot I wish you would have saved all the parts
syfi
Mar 28, 2026 04:14 PM
Sep 28, 2015 07:40 PM
Ralph289
Sep 21, 2015 09:34 PM
Dgiomatch1
Sep 20, 2015 01:05 AM
Idrenak
Sep 19, 2015 08:17 PM
