White exhaust smoke normal?
Old Nov 15, 2012 | 07:11 PM
Indelibility's Avatar
Default White exhaust smoke normal?
Can't say I've really noticed it until it got a bit colder outside, but my exhaust is constantly pushing out white smoke, not so much when under gas, but it's noticeable at idle. I know it's normal to see it at startup, but even after the engine is warmed up I still see exhaust smoke in my mirror.
Coolant looks fine, engine temp is normal, just replaced plugs/wires about 5,000 miles ago. Car is completely stock. Do y'all see white exhaust smoke normally as well? Or do I have an expensive repair coming up?
Old Nov 15, 2012 | 07:25 PM
Default Re: White exhaust smoke normal?
vapor more than likely....now if it turns blue, and smells like oil, I'd worry....
Old Nov 15, 2012 | 08:48 PM
PNA's Avatar
PNA
Depending on how cold it is, it's likely just vapor. However, if it's not that cold outside then it could be (not saying it is) and internal head gasket leak. It could be slow, but enough to cause the smoke. If you've check the coolant levels and there's no appearence of a leak, keep checking it to confirm theres not a slow drain. You could also do a pressure test.
Likely nothing, but I do know mine doesn't do that in cold weather. It will upon start up but once it warms up, unless it's really cold, it subsides quckly.
Old Nov 15, 2012 | 11:04 PM
I'm hoping it's nothing, not really looking forward to a head gasket job. it's just that I can still clearly see the exhaust after 20 minutes of driving, that's what has me worried.
No weird smells though.
Old Nov 16, 2012 | 12:15 AM
the best way to check if you have a problem, or anyone that thinks they have smoke coming out the exhaust.
at night get in front of some and floor it, you may see black smoke at that time,,or blue smoke hope not white smoke ,,repete this 3 or 4 times as you may just have carbon build up. after 4 times it should not smoke any more.
if you get blue snoke on start up (first start of the day that is valve seals,or valve guides letting oil leak into a cylinder, upon start up it burns)
1 blue smoke =oil
2 black smoke= fuel
3 white smoke= water
jim
Old Nov 16, 2012 | 02:14 AM
1 blue smoke =oil
2 black smoke= fuel
jim
Had a buddy check it out, it's not black or blue smoke. It's white, but said it's not as excessive as I thought. I may get my mechanic to check it out anyway.
Old Nov 16, 2012 | 08:01 AM
if it only happens when the car is cold (first start and until it warms up) it is condensation, and all cars do that ,,
the hot exhaust on to clod manifolds and pipe you may see drops of water coming out the exhaust tip
if this is what you are talking about , don't do anything except clean your exhaust every day, Oh! this happens mostly in the winter ,think about it , see cars with white smoke coming out on cars stopped at a red light with snow on the ground. jim
Old Nov 16, 2012 | 08:42 AM
Yeah, I'm an idiot. Just paranoid about a high mileage car. All good
Old Nov 16, 2012 | 10:30 AM
Bill F's Avatar
Warm exhaust mixes with cold is the same result as when it is cold out and you exhale produces a visible vapor.
Old Nov 16, 2012 | 03:33 PM
actually, you are not an idiot. It was a good question, and the type of question we old guys like to answer....and you care about your car....so good for you....
Old Dec 28, 2012 | 11:05 PM
vallartenses's Avatar
White smoke can often mean that antifreeze is somehow getting into your combustion chamber versus simply hot exhaust flowing into a cold exhaust system. Easiest way to tell is simply to put your hand into the vapor for a few seconds, then rub your fingers together. If it's antifreeze it will feel slightly slippery when you rub your fingers together.
TerryR
Dec 13, 2019 03:27 PM
minimayhem
16
Aug 23, 2016 07:47 AM
crossfireE
Oct 2, 2015 01:40 AM
Charlesl
Sep 30, 2015 10:46 PM
Sep 28, 2015 07:40 PM
