Plug and play replacement amp?
Old Feb 12, 2013 | 11:19 AM
zombiehunter's Avatar
Default Plug and play replacement amp?
My amp seems to be fried. I just want something I can swap out without paying the stealership $600.
Old Feb 12, 2013 | 11:43 AM
Mrmiata's Avatar
Default Re: Plug and play replacement amp?
Changing rear subs too? Otherwise you'll have to figure out what your going to do about dual voice coils on the OEM ones.
Unfortunately.. one thing leads to another on these amps for the most part.
They do pop up on Ebay on occasion.
Old Feb 12, 2013 | 11:58 AM
Is it going to be cheaper than a new amp? Is it hard? What speakers/subs to you suggest
Old Feb 12, 2013 | 11:59 AM
Someone was selling a OEM head unit AND an amp the other day here.
Do a search .......
Old Feb 12, 2013 | 12:16 PM
Mrmiata's Avatar
And since you haven't said anything about checking things.. I'm guessing you have checked all fuses? Fuse 23 in the under hood accessory block. I can't recall if the amp itself has one built into it.. I know the stereo head unit does...
Old Feb 12, 2013 | 01:00 PM
I'll check the fuse, but it was working intermittently then it just stopped. The headunit checked out fine.
Old Feb 12, 2013 | 01:03 PM
As others suggested, if you do not want to replace the head unit and subwoofers, and then probably the other speakers, it would be best to simply buy a used one here from someone that has upgraded the stereo, peel back the carpet on the passenger side floor board and swap it out
Old Feb 12, 2013 | 03:08 PM
I'll try to do that.
Bone stock but EC 65mm pulley and Needswings CAI and then EC tune on the way
Old Feb 12, 2013 | 03:17 PM
see if this is sold :
https://www.crossfireforum.org/forum...?highlight=amp
xfClifford
Mar 3, 2021 04:52 PM
PNA
Nov 12, 2020 04:44 PM
massanu
Feb 20, 2019 07:06 PM
BrenLW
Aug 5, 2015 04:53 AM
pioneer4x4
Jul 27, 2015 02:04 PM
