Headlight Bulb Replaced Indicator Light Goes On
Old May 4, 2013 | 11:36 PM
jrp758's Avatar
Default Headlight Bulb Replaced Indicator Light Goes On
I own a 2005 Chrysler Crossfire. I recently had to replace a headlight bulb. I decided to replace all H7 bulbs and the foglight bulbs. With Sylvania HZ ZXE bulbs and 9006xs Sylvania ZXE bulbs. However everytime i turn on the headlamp low beam bulbs on the dashboard instrument panel light out indicator appears. These bulbs should be the correct replacement. Is there any reason as to why this indicator will keep coming on only when I turn the bulbs on?
Old May 5, 2013 | 12:08 AM
robby363's Avatar
Default Re: Headlight Bulb Replaced Indicator Light Goes On
Are you sure you don't have another bulb out like a parking or license plate light?
Old May 5, 2013 | 07:26 AM
jrp758's Avatar
Yes. I read all the forums. It's only when I turn the lights on. I did check the park lights and license plate lights. They look good? Could it be the replacement bulbs? I guess I could try putting the old bulbs back in to see if the light goes off?
Old May 5, 2013 | 10:21 AM
RL67037's Avatar
Does the bulb out indicator light when you turn your light switch to the first position (parking lights) or when you get to the second position (head lights)?
Old May 5, 2013 | 10:45 AM
Welcome to the forum.
You started two threads and this always splits the answers into two and gets confusing. Also there is a forum for exterior and lighting and it would be best to use that.
2004_
Jul 9, 2025 12:39 AM
Hoppy
Dec 7, 2018 07:36 AM
jgreen
106
Sep 18, 2017 11:46 PM
skeet370
Jul 18, 2015 01:02 PM
KwehCat
Jul 16, 2015 04:48 PM
