Gas pedal mod question
Old May 5, 2013 | 09:11 AM
Whoapony's Avatar
Default Gas pedal mod question
Has anyone tried to modify their gas pedal? I remember reading a DIY for 05 and up mustangs when I had mine and it made me think of trying it out. I wanted to see if anyone has already tried it, If so did it work and where did you get the pedal. I tried a search and all I can come up with is the sprint booster, which if the mod works does the same thing for free basically!
Old May 5, 2013 | 10:07 AM
Default Re: Gas pedal mod question
You talking about this ?
THE "MINI SPRINT BOOSTER" MOD:
I did the item 4 steps to reset the TB, but only pressed the pedal to the hard spot, instead of to the floor. And be sure to leave the key in during step (4) .
The results were great. Due to this method, at about 1" typical pedal stroke, you are telling the ecu and TCM that there is about 20% more load than before the mod. The benefits include:
-> higher shift points
-> quicker/easier to downshift
-> a more peppy drive with less lag
-> cost is $0
As far as 0-60 or 1/4 mile times, no improvement there.
Read more: Free DIY mini sprint booster - MBWorld.org Forums
Old May 5, 2013 | 10:13 AM
Whoapony's Avatar
No, but I might give that a try! The mod I was speaking of involves opening up the pedal housing and adjusting the contacts inside. Here is a link for the mustang.
DIY THROTTLE RESPONSE MOD (MUST SEE!) - MustangForums.com
Old May 8, 2013 | 06:32 AM
Whoapony's Avatar
Well if anyone has a pedal they wanna sell cheap I can give this a try!
Old May 30, 2013 | 03:01 PM
Callahan's Avatar
I put a Sprint Booster in. While it does not do any HP increase, it does improve the throttle response.
Old May 30, 2013 | 03:22 PM
With a throttle by wire system, I would be very weary to mess with the electronics, you may end up with an all the time accelerating XF like the Toyotas were doing a few years ago
NeedsWings
70
Mar 24, 2023 09:48 AM
LE Cross
Oct 17, 2016 06:35 AM
gblack32
Sep 7, 2016 08:27 PM
SparkieSRT6
Jan 11, 2016 10:49 PM
xfClifford
27
Nov 10, 2015 10:08 PM
