Oil Consumption In Test Cars (Consumer Reports)
Old Jul 1, 2013 | 02:02 PM
Default Oil Consumption In Test Cars (Consumer Reports)
Ran across this article earlier today. Interesting findings being reported by Consumer Reports.
Later,
Old Jul 2, 2013 | 12:29 AM
JEFASOLD's Avatar
Default Re: Oil Consumption In Test Cars (Consumer Reports)
I am not surprised to see this. I have 5-40 Royal Purple in my Xf now and since I don't run it in winter will think about 10-40 next change It just seems logical that ultra light oil would seep through areas that heavier oil would not.
Old Jul 2, 2013 | 12:33 AM
Selbyl's Avatar
I know some people I've talked to that have VW 2.0T engines started using a slightly heavier oil because the turbo would slowly leak/burn oil.
Old Jul 2, 2013 | 04:08 AM
I must be lucky, then. I change oil yearly, or at 7000 whichever comes first and have never had to add any extra Mobil1 0-40.
I'm now at 53,000 miles.
Old Jul 2, 2013 | 12:35 PM
lildaddym's Avatar
I think any oil consumption is bad...is there a recommended oil that is thicker than the 0-40 that is standard? This could explain why some of us have sooty exhaust?
Old Jul 2, 2013 | 01:38 PM
If you did not have any oil burnt or lost you would be in trouble soon enough.
Engines with close fits need thinner oil especially at start up. Put in some really thick oil and get to meet your pistons for the first (and last) time ... you'll find them welded to the bores.
Old Jul 2, 2013 | 01:43 PM
lildaddym's Avatar
So, a 5W-40 would not be prudent? I was checking the 229.5 specs and it's listed as acceptable...
Old Jul 2, 2013 | 02:37 PM
5w-40 is fine especially where you are. Most oil is burnt I would guess when the car is warmed up, accounting for the most running time as well.
You said a thicker oil so I thought you meant over the 40 weight. When cars burnt oil in the old days they went to oil that was like molasses when cold. It made the wear faster but there was less blue smoke to show the buyer.
Old Jul 2, 2013 | 03:05 PM
lildaddym's Avatar
I was just considering something thicker on the lower range... I may do that the next oil change...
ingsoc39
Jul 7, 2022 04:25 PM
mhajek18
Dec 30, 2015 03:40 PM
GraphiteGhost
Jun 12, 2015 12:04 PM
Ephr8a
Jun 4, 2015 12:42 PM
xfmad
16
Nov 21, 2003 12:13 PM
