Belt Squeak when cold
Old Sep 18, 2013 | 09:28 AM
judyd63's Avatar
Default Belt Squeak when cold
I just purchased a 2004 Crossfire and when I start it up cold I hear a intermittent squeak from what appears to be the serpentine belt. I am thinking maybe the tensioner? Anybody else had this problem?
Old Sep 18, 2013 | 09:34 AM
Default Re: Belt Squeak when cold
in this order :
1. tensioner pulley
2. idler pulley
3. water pump
4. alternator
5. power steering pump ( check the fluid level )
6. A/C clutch bearing
Old Sep 18, 2013 | 09:41 AM
judyd63's Avatar
Thanks! I will check out the easy things first and if that doesn't do it then I guess I will be taking to the shop.
Old Sep 18, 2013 | 09:48 AM
Are you familiar with how to check noisy bearings ?
Old Sep 18, 2013 | 09:53 AM
judyd63's Avatar
I'm afraid not. I really don't know how to do much at all at this point but I am trying to learn. The squeak seems to be coming from the driver's side of the belt and only when cold. I just figured before I took it to the shop and paid big bucks, I would see if there was anything I could check for myself.
Old Sep 18, 2013 | 10:13 AM
Remove the plastic fan assembly :
1. unplug the big connector going to the fan.
2. remove the 2 metal clips that secure the fan assembly at the top ( just pry up with a screwdriver )
3. remove the fan assembly ( requires some effort getting it out past all the hoses, but it can be done )
4. remove the serpentine belt by placing a 17mm socket with a pull bar or long ratchet on the boss extrusion of the idler assembly and rotating clockwise. ( take a mental picture of how the belt runs first - better yet, make a drawing )
With the belt removed, you can spin each bearing/alternator etc by hand and listen for any nasty noises.
You CAN do this without removing the fan assembly, but you will have much better access with it out of the way.
Old Sep 18, 2013 | 02:16 PM
judyd63's Avatar
Thanks for all the info. That might be a little ambitious for a newbie like me!
Old Sep 18, 2013 | 02:58 PM
Mrmiata's Avatar
Location? We do have some forum members willing to lend a hand if your local to them..
Old Sep 18, 2013 | 05:41 PM
judyd63's Avatar
I live in central Virginia, outside of Charlottesville. It would be nice if there was someone nearby that knows about these cars. Let me know, thanks!
jimf
Oct 10, 2015 10:22 AM
4drturbo
Oct 2, 2015 12:58 PM
Sep 26, 2015 10:21 PM
Sep 25, 2015 07:46 AM
RiderJC
Sep 7, 2015 11:19 PM
